daedalusflies
Well-known member
I have been using Cerious Software's Thumbsplus for my digital images well before Lightroom or Picasa existed. You will be pleased to know that it recognises Foveon X3F files and is able to edit them (including colour balance, resizing and MOST of the usual functions one needs) and also able to batch process. It does not compare to SPP's fill light ability when that function is called into use, but otherwise in well exposed pictures that need little doctoring (by the way, I find the way it adjusts hue and saturation on the Raw X3F files a good shade 'gentler' than SPP's software algorithms), the ability to batch process comes into its own. Worth a try to any of you out there who want to batch process your X3F images to some degree and the link below to the site is where a trial copy is downloadable.
BTW - once you install the program, the thumbnails should be made quite easily. Right click on an X3F thumbnail and select the 'Configure type' submenu item.
Choose the edit file dialogue - select 'command' from the pick list and, to the right of that, use the browse button (shown as '...') to direct it to your Sigma directory in the C drive (sorry, am a Windows user for all you MaC lovers out there). This is usually on the C drive and under Program Files/ Sigma/ Photo Pro. Select Sigma Photo Pro.exe and that is just about it after clicking on OK to close the dialogue!
Good luck and let me know if it is any use to all of you looking / waiting for Lightroom to be X3F friendly.
http://www.cerious.com/
