The beta is running very very slow on 1 gig ram dell centrico duo
core ...
Yep, the released LR V2 is slow. However, I don't think ANYTHING will
run very fast on 1Gb of RAM. Most of that gets used just for the
operating system. You'd want to add a gb of memory for sure.
I am still evaluating if it is worth getting one of these .. it seems
more like an advanced RAW processing software without having to save
to TIFF and/or JPEG before final processing ???
I cannot recommend Lightroom enough. You simply CANNOT compare it to
Bridge/Photoshop. They might have overlapping features when specs are
compared, but the user experience is vastly different.
I have to try the CS3 to see if the cataloguing is similar/at least
useable as in LR 2.
See above, LR is vastly superior in my opinion. It DID take me a
little time to get used to it and I came close to giving up several
times. I took doing an actual project, from start to finish, to
appreciate what LR does. Prior to that, I was just poing around and
playing and nor appreciating the efficiencies. After doing a real
project (a photoshoot) I was hooked and now cannot imagine using
anything else. I have Bibble, DPP, CS3 with Bridge and Rawshooter and
much prefer Lightroom.
Anybody in the same position deciding between CS3 or LR2 ?
Not me. I have both. With LR 1.4.1 I found myself using LR about 80%
of the time and CS2 about 20%, only when I needed layers and
localized editing. Now with LR2, I am anticipating that percentage
will change to 90/10 maybe even more, in favor of Lightroom. I NEVER
use Bridge anymore and I NEVER use ACR, preferring LR to manage the
raw conversion, the opening of Photoshop and the automatic stacking
of the PSD file. I therefore totally avoid having to be disciplined
in my saving of files (LR does all that for me).
I sometimes use Photoshop for printing as it can proof the image
prior to printing. But I have a color managed workflow and trust the
process. My prints out of LR are wonderful.
I am wondering if LR2 can do localised noise reduction also ??? I
know about the dodging and burn thingy.
No, does not look like it can (excellent idea though!).
Ta
Be a torch bearer ...
S3 IS
New world in dSLR, yes Canon. No particular reason why I chose the
brand, just 450D comes at the right time with the right features I
want. I am determined to get the best results out of its limitations
or what not.'
My passions:
http://www.holeepassion.com
http://www.suprememastertelevision.com
Albert
Gear: 5D, 30D, EF17-40L, EF24-105L IS, EF100-400L IS, SIGMA 10-20EX,
Manfrotto 3021PRO, Induro CX213
http://www.albertdebruijn.com (now with free Lightroom presets)
http://albertdebruijn.zenfolio.com
