Kenko 800mm& 500mm F8 DX
bkj
US
Kenko 800mm F8 DX
http://dc.watch.impress.co.jp/cda/parts/image_for_link/140130-8578-3-1.html
http://dc.watch.impress.co.jp/cda/parts/image_for_link/140132-8578-3-2.html
Kenko 500mm F8 DX
http://dc.watch.impress.co.jp/cda/parts/image_for_link/140134-8578-6-1.html
http://dc.watch.impress.co.jp/cda/parts/image_for_link/140136-8578-6-2.html
Too bad F8 could be too slow for most cameras to AF.
Cheers
Fujifilm S5 Pro, S3 Pro
Tokina AF 12-24/4.0
Nikon AF-S 18-200/3.5-5.6G VR
Tamron AF 28-75/2.8
Nikon AF 50/1.4D
Sigma AF 150/2.8 Macro
The 800mm mirror should be able to, assuming it's an AF lens (which I doubt it is). However it should do fine with focus confirmation.
Mirror lenses use a larger physical aperture than than the focal length and aperture ratio would suggest. The reason for this is that there's a big black spot in the middle which reduces the effective exposure. If they just sized the diameter for f/8, exposure wise it would be 2/3 of a stop under. Not a problem with auto exposure camerasSo they add 2/3 of a stop in diamter. That means the light is coming in at up to f/6.3. That's close enough to f/5.6 to light up the AF sensor (third party lens makers do this all the time).
Minolta/Sony has an AF 500mm f/8 mirror lens.
http://en.wikipedia.org/wiki/Minolta_AF_500mm_Reflex_lens
And in case you don't believe me, 500/6.3 = 79mm. According to the specs on the linked page, the front filter size is 82mm.
Seen in a fortune cookie:
Fear is the darkroom where negatives are developed
is this a kenko branded version of lens's already produced by third parties ?
The lens's look similar to some of the ebay and back-of-popphoto adds that I have seen over the years.
parties ?
AFAIK, both the 800mm mirror and the 500mm fixed aperture lens are new designs. They're stated to be specifically for APS-format cameras too, not 35mm.
As an aside, the design constraints on a mirror lens means they all tend to look pretty much the same. There's only so many ways you can style a fat can with a large opening and a small mirror in the middle.
Pics: http://www.flickr.com/photos/jannem/
Blog: http://janneinosaka.blogspot.com
Now that was an interesting design. How was the blur characteristics? The major drawback of mirror lenses is usually the rather distracting donut-shaped out of focus highlights. I guess the patent is the reason nobody else has bothered with the design.
Not that the box design is a major improvement from an esthetic standpoint... :)
Looking at the lens and guessing it was made in the '70s, the patent must have expired.
