Hi,Hey all,
Any idea how to connect a gps to the 20D so I'd get coordinates
recorded with the pic data?
thanks
I bought that little devise, which is very nice because it also display your GPS coordonate in real time..so great if you're lost in the forestHey all,
--thanks
Let's say you did get lost, how would you use it to get back? I was recently at a very familiar wooded area but once inside, I traveled to some areas I had not previously explored. Everything looked the same no matter which way I looked. It was overcast so that was a bit disorienting. I eventually did see a landmark that was different so knew which way to go. Having a GPS would have been useful.The Holux M-241 is the only GPS logger that actualy can show the GPS
If you already have a GPS that can create a log file, you can use
that devise as well..
I did not have a GPS and wanted a devise that could log my route and
also show me the real time coordonate so that if I get lost in the
woods, I could track my way back.
And you ordered it directly from that eBay store?So far no other devise does it and you need a full features GPS to
get this.
At around 60$, it's a really nice thing.
http://www.pbase.com/zylen
'Never argue with an idiot, they drag you down to their level and
beat you with experience'
first you have to take note on the coordonate before you start, like where your car is parket. Second you must make sure your battery in the GPS is freshLet's say you did get lost, how would you use it to get back? I wasThe Holux M-241 is the only GPS logger that actualy can show the GPS
yes, from this excellent seller..very fast and reliable shipping too:And you ordered it directly from that eBay store?So far no other devise does it and you need a full features GPS to
get this.
I know you mean well but please do not embed my images into the
forum. Thanks for respecting that.
http://www.pbase.com/golfpic/some_recent_shots
http://www.pbase.com/golfpic/a_red_fox_family
Thanks for sharing the above Daniella. A logical way to do it. I am wondering if a full-featured GPS would actually lead you back to the original starting point with arrows etc. I'll find out.first you have to take note on the coordonate before you start, likeLet's say you did get lost, how would you use it to get back? I wasThe Holux M-241 is the only GPS logger that actualy can show the GPS
the GPS is freshthen you write down those coordonate before you
start..
If you get lost, you can get the GPS location in order to get back to
your point of origine by going in the direction you need.
for exemple lets imagine that you started at 73.40.10 - 75.50.20
when you are lost you check the GPS coordonate. lets say you are now
at 73.30.20 - 75.50.10. you walk about 50 feet in the direction you
think is right and you check again..you must get closer to your point
of origine, not getting farther away from it.
if your next step bring you to 73.20.30, that means you are getting
away from your original position..if your next step now read
73.40.02, that means our are getting closer to your origine.
You must make sure the number of the coordonate are getting in the
right direction, wich is closer to your origine. So you might not
see exactly where you are on a map, but you would be able to see if
you are getting away from your original position or not.
the trick would be to walk, check GPS, getting closer? fine, that's
the right direction. Getting away? opppsss..wrong direction.
it would be a bit of trial and error probably with the direction but
it's a very good way to get back on track for sure.
I remember this story. Wow, talk about unexpected things, like fog, happening at the wrong time. You are one tough and brave lady and resourceful with a good head on you in such a situation. Many people would panic. Panic doesn't help thoughI once got lost in the huge Giant Sequoia NP totaly alone because
suddent very dense fog got in from nowhere. I could not see 3 feet
in front of me at some point so no landmark available. It was about
one hour from sunset, I was alone, with wild bears and mountain lions
maybe...I was prepairing to spend a very long and cold dark night in
the forest and I found my way back only by keeping calm and sheer
luck.
I wish I had a GPS then. I would have tracked my way back no problem
in the fog.
Of course you MUST write down the coordonates before you start in
order to get back there.
Thanks. I just read it.yes, from this excellent seller..very fast and reliable shipping too:And you ordered it directly from that eBay store?So far no other devise does it and you need a full features GPS to
get this.
http://stores.ebay.com/aplumdeal
It's a nice little gadget.
It is also fun to watch my route later at the end of the
day..remember years later where I took this or that photo...
I will send you a link to download a googleearth file wich includes
photos so that you can see what it can do.
It sure would.Thanks for sharing the above Daniella. A logical way to do it. I am
Actually that's not exactly like that. The mapped GPS's are quite capable.It sure would.Thanks for sharing the above Daniella. A logical way to do it. I am
Most proper GPS devices will allow you to save a location and then
show you the direction to that location. Of course it only shows it
as the crow flies, but that's a lot better than nothing.
Frank Hollis
Mass Spectroscopist in the UK
Can0n 2oD and 4oD
I'm glad you like this so much (even giving advices now!first you have to take note on the coordonate before you start, like
start..
Daniella, I think you'll be better off with a proper GPS in the long run - it's just more reliable, has better reception, but most importantly it's not not even comparable in usefulness to the simple device you're using.I once got lost in the huge Giant Sequoia NP totaly alone because
luck.
in the fog.
Hey all,
thanks
I bought that little devise, which is very nice because it alsoHey all,
the forest
The Holux M-241:
http://cgi.ebay.com/Holux-M241-Bluetooth-USB-GPS-Data-Logger-Receiver-LCD_W0QQitemZ280217083925QQihZ018QQcategoryZ148490QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I first start the devise when I enter a location..then let it run
until I finish shooting that day and stop it there.
First you must syncronize your clock with your camera so that the
time tag in your photo will correspond with the time tag of the
correct GPS coordonate in the GPS devise.
Then I use a little free program called geosetter to geotag my photos.
You can also create a google Earth file which you can send to someone
and if that person has googleearth installed, it will show your route
with your photos embedded
neat thing.
--thanks
sure..just export the whole thing as a .kmz file and that will include all the photos with them.hey,
I've started using gpicsync to sync the gps coordinates with my
photos and have them exported to google earth. is there a way to host
the pictures somewhere so i can email for example the google earth
file to ppl so they can view the tracks and photos without having to
send them each and every photo?
sure..just export the whole thing as a .kmz file and that willhey,
there is a hick though, because google map usualy resize the photos
to viewing so they look not as sharp as the original photos.
.kmz files contain all images inside. They are zipped google files
and you just need to click on it to load in google and that will show
all the pics.
