Detailed steps for mattes & frames in PS6
Dave:
Thanks for your post of the instructions for the mattes and frame. In following your instructions (repeatedly) I can't seem to get the lighting on the bevels between first matte and picture, and second and first mattes to coincide. If the darker edges are on the top and left edges of the outer bevel, then they are on the bottom and right of the inner bevel. This results in a disconcerting effect as if the inner matte is raised. Any suggestions?
Randall Smith
Randall...In the exercise, I used an angle of 120 degrees on all inner shadows and bevels whenever either of that layer style was used, which mean you must "uncheck" global light 30 degrees. See if that doesn't correct your problem...Dave
Dave:
Randall Smith
I guess you could save the process as an action, but would have to
have one for portrait mode and one for landscape mode..
No. Instead of putting a pixel value in when you enlarge the canvas, change the units to percent and enlarge by 10%. If you do that, it will work for both portrait and landscape.
Cricket
Has anyone created an action for this awesome matte and frame? For some reason, after several attempts, I cannot get it right. It looks horrible.
If someone did create the action, please let me know.
Someone in the forum did create an action. I apologize that I don't remember who it was -- but I have a copy that you can download.
http://webpages.charter.net/ed_lisaneal
The first action is the one you want.
looks horrible.
Lisa
Yes there was, it was by MHL some time ago, can't find it though. Perhaps you can. I think the hangup might be at #11 for the landscape or portrait mode. In any event, why try to make one on your own. Print out the steps, start a new action recording and have at it. Best way to learn for me.
Dave
looks horrible.
Lisa
This was such a great post, I just wanted to revive for new users to use. Thanks Dave.
I was wondering also, does anyone know how to create multiple "holed" mattes. For instance, using techniques similar to this, how can I create a picture frame and matte with spots for say 4 pictures (4 holes cut in the matte) using Photoshop. If anyone can provide somewhat detailed step-by-step instructions, I (and I'm sure MANY others) would greatly appreciate it.
Thanks again Dave for this post; it has been extremely useful.
I took the time to write out the steps I followed to create a
matted and framed picture in essentially 2 sections, the matte, the
frame. You can stop at the matte and print for your own real
framing or continue and add the frame for email or internet. I'd
like to thank MHL and Brian for the tips and information they
provided in the past. I hope this helps those on this forum that
might have an interest in this process. I know there are other
ways of doing this, but this is where I am at present and I've
learned alot getting to this point. I always welcome and
appreciate suggestions and improvements..Dave
http://www.pbase.com/davidjaseck/photorestoration
This is done in PS6...
OK..Lets us use the hypothetical of a 5"X7" picture @100 ppi that
you want on a 8"X10"matte.
1. Open image in PS6. Before you do anything else, double click
background copy in the layers pallet and rename “Photo”
2. Select > all. Go to Edit> stroke, 2 pixels in black
4. Make duplicate layer.
5 Go to Layer> layer style> innershadow add 5 pixel distance and
size. You can adjust these to your own taste later. Important,
keep the angle on everything at 120 degrees
6. Make new layer, title it “First Matte”. Drag it to
the bottom of the layers pallet. Go to Image> canvas size. Add .5
to both the width and height of this layer. Click OK.
7. Go to Select> select all. Go to Edit> stroke. Add 2 pixel black
stroke to the “First Matte” layer. At this point
select a color for the first matte. Try a medium color for this
exercise.
8. Still on the “First Matte” layer, go to Layer> layer
style> bevel and emboss. Style “Inner bevel”, 7 or 8
pixel size, click the "down" button. Make sure angle is always 120
degrees. You can add a texture to the 2 mattes any time you choose.
9. Make new layer, title it “Second Matte”. Drag it to
the bottom of the layers pallette. Go to Image> canvas size and
resize to 8”X10”. Click ok.
10. Select a complimentary color and add with Paint Bucket. Add
texture if desired.
OK, at this point you should have a finished matted picture. You
can save and keep all the layers in this picture for future changes.
Now for the frame:
11. Make a new layer. Title it “Frame” and drag it to
resize the “Frame” layer. Add 1 additional percent to
the short side. For example, Landscape - width 104%, height 105%,
Portrait - Width 105%, Height 104%. Fill using paint bucket with
color of your choice. (Got this from MHL, Thanks, don't know why
it works this way, but hey!)
12. Go to Layer, layer style> inner shadow - add. Go the bevel and
emboss, select “outer bevel” and click the down button.
13. Activate the “Frame” layer, Go to Layer> layer
style> bevel & emboss. Select “inner bevel”, click the
“up” button. You might at this time stroke the frame
with a 2 pixel black stroke
At this point you should have a matted picture with a frame. Lets
put a background under it.
14. Make a new layer, title it “White Back” and drag it
to the bottom of the layers pallette.
15. Go to Edit> canvas size and resize to 120% on both height and
width.
16. Fill white color with paint bucket.
17. Go to “Frame” layer, activate, go to Layer> layer
style> drop shadow. Set to distance 50 pixels, size 50 pixels.
That’s about it folks. Remember, keep the angel at 120
degrees (unclick the "global light". Hope I didn’t forget
somethingl..Dave
For those who may not know, I've made the above instructions into an action for 5X7 pictures with 8X10 mattes for both vertical and horizontal pictures. It can be had in the Forums Actions folder. It does not include the frame as it was created for print purposes. However, for those that would like a frame, it can be easily modified by adding on the frame instructions for web purposes...Dave
http://www.geocities.com/kafuensis/
background copy in the layers pallet and rename ?Photo?
6. Make new layer, title it ?First Matte?. Drag it to
stroke to the ?First Matte? layer. At this point
exercise.
8. Still on the ?First Matte? layer, go to Layer> layer
style> bevel and emboss. Style ?Inner bevel?, 7 or 8
9. Make new layer, title it ?Second Matte?. Drag it to
resize to 8?X10?. Click ok.
texture if desired.
Now for the frame:
11. Make a new layer. Title it ?Frame? and drag it to
resize the ?Frame? layer. Add 1 additional percent to
emboss, select ?outer bevel? and click the down button.
13. Activate the ?Frame? layer, Go to Layer> layer
style> bevel & emboss. Select ?inner bevel?, click the
?up? button. You might at this time stroke the frame
14. Make a new layer, title it ?White Back? and drag it
width.
17. Go to ?Frame? layer, activate, go to Layer> layer
That?s about it folks. Remember, keep the angel at 120
degrees (unclick the "global light". Hope I didn?t forget
somethingl..Dave
exercise.
texture if desired.
Now for the frame:
width.
somethingl..Dave
now, would you list the steps you take to get such beautiful shots to put in them? :-)
You are a gem of a person to share such good work!
Walter K
to put in them? :-)
Walter K
--I have been using buds frames and getting lazy. i had this printed out from way back last year. tried it several times today and just couldnt get it right. found my way back here to the thread and realized the glitch in step 12. about to try it again. good to resurrect one of my very earliest photoshop efforts.
Vera
to put in them? :-)
Walter K
Vera
--Well it went much easier a few months into photoshop for me. I remember struggling with this in october last year.
here is my quick effort tonight done in about 10 minutes as against about 10 hours back then;
Vera
Although I have played with Photoshop 6.0 and 7.0 now for about 1 1/2 years, I have never attempted a frame.
I found this link by Phil's great search engine for this site. Thank you Phil.
Dave, thank you for the step by step process in creating a frame. I would never have been able to do this without this process.
I also wanted to post here so that if someone else has not seen this, they will have the chance.
I need some more help in choosing colors, (I'll have to play around with them), but at least I completed the whole process.
Any suggestions for a better colors is also greatly apprecitaed. =)
DeeDee G.
exercise.
texture if desired.
Now for the frame:
width.
somethingl..Dave
DeeDee G.
http://www.pbase.com/deedee_g/root
