Phil Sexton83509
Leading Member
I sure hope that someone will respond to this query. Several of us who use Elements have been trying to use the process below to do some matting and framing. It doesn't track in Elements.
I get hung up on Step 5. The Layer Styles is apparently different in Elements and the full version. There is no method (that I know of) to specify the thickness (?) or position (?) or angle (?) or color (?) of a bevel or shadow. There is just a little black line added to the image.
I took the time to write out the steps I followed to create a
matted and framed picture in essentially 2 sections, the matte, the
frame. You can stop at the matte and print for your own real
framing or continue and add the frame for email or internet. I'd
like to thank MHL and Brian for the tips and information they
provided in the past. I hope this helps those on this forum that
might have an interest in this process. I know there are other
ways of doing this, but this is where I am at present and I've
learned alot getting to this point. I always welcome and
appreciate suggestions and improvements..Dave
http://www.pbase.com/davidjaseck/photorestoration
This is done in PS6...
OK..Lets us use the hypothetical of a 5"X7" picture @100 ppi that
you want on a 8"X10"matte.
1. Open image in PS6. Before you do anything else, double click
background copy in the layers pallet and rename “Photo”
2. Select > all. Go to Edit> stroke, 2 pixels in black
4. Make duplicate layer.
5 Go to Layer> layer style> innershadow add 5 pixel distance and
size. You can adjust these to your own taste later. Important,
keep the angle on everything at 120 degrees
