SoxPadresFan
Well-known member
Well, I am buying a d60 - still looking for a place that can get it to me sooner rather than later. I am an amatuer but eager photographer who hopes to greatly increase my skill level over time. Right now, however I am new at all of the lens decisions. I have read tons of these threads and some sinks in but some goes over my head. After reading for an hour, I had made decisions, thenm I read more and changed my mind and now I have changed it again - very confusing. So I will burden you all with this task - if you think you are upto the challenge.
Let me try and put it all down and you can choose to help in zero or all areas of my message. Thanks in advance:
Assuming my most frequent photo ops are
sports (baseball, football, and golf) and nature (zoo, parks, scenery)
for sports I would be in press areas at times and in spectator seats at times
I might occasionally do indoor sports, but very rare - in other words - low light is less relevent in decision
I'd obviously also like to take photos on vacations, in museums, of family, etc.
With that said, I'm trying to figure out these lens options. Money is a consideration, but I will be able to take the philosophy that I don't want to compromise now - if in the future I will constantly say - I should have gone with the more expensive lens.
What are the pros and cons in the following lens comparisons - which would be better for me:
1) Now I know I need a 28-70 type lens - I guess these would be my options:
canon 28-70mm f/2.8L USM Lens ($1299)
canon 28-105mm f/3.5-4.5 II USM Lens ($399)
canon 28-80mm f/3.5-5.6 II Lens ($190)
canon 35-80mm f/4-5.6 III Lens ($129)
is the f/2.8 and the fact that its an "L" really make $900+ in difference
2) next, I want a good zoom lens and it is important to me that I can get really close - I'd love to get close enough to see beads of sweat on a pitcher. Considering that I may be taking shots not only from photo boxes on the field, but also from the stands (though I'm not even sure they would let someone take a lens that size thru the security at the turnstiles anymore) should I be trying to get up to 400mm (which I understand is 640mm after the digital multiplier of 1.6). Should I be fine with the 200 mm? Do these converters that turn a 200 into a 400 work? With this size lens - how important is the 2.8 vs. 4.5 issue - in other words what is the sacrifice I'm making to get to 400mm? From everything I read - I definitely want the Image Stabilization here. I guess I'm trying to decide between these - unless someone knows of a more reasonably priced option:
canon ef 70-200 L IS 2.8 Lens ($1999)
canon ef 100-400mm f/4.5-5.6L IS USM Lens ($1599)
3) next I guess I need something like the 16-35. I would think that this would be my least frequently used lens - and feel pretty confident (though remember I have very little experience with SLR lenses) that I could skimp a little here. By skimp, I mean - try and get under $1,000. Is that right? So for arguments sake lets throw these 3 lenses in the mix:
canon ef 16-35mm f/2.8L USM ($1499)
canon ef 20-35mm f/3.5-4.5 USM Lens ($544)
canon ef 22-55mm f/4-5.6 USM Lens ($199)
or can I just get a prime lens like:
canon 20 mm f/2.8 USM EF Lens ($529)
but if I got the 28-70 above - how important will it be to get down to 20-22mm?
4) finally I have more of a general question about ways to save $. I think I understand the "L" lenses are just much better quality. and that buying canon vs. something like a sigma - is a quality issue also. I'm not sure however if that matters at my level of skill - does it? should I be looking at prime lenses. It seems like adding a canon ef 50mm f/1.8 II prime lens for $99 to the collection seems worth while - whats $99 more dollars if I spend $1k-4k on all of these lenses?
In the end, I guess I am partailly wondering if maybe I should just go with something cheap like this package I saw at Ritz "Sigma - Two Lens Zoom Kit with 28-80 & 70-300 plus Gadget Bag for Canon AF" - for $280. Then use those until they fall apart on me and/or I get annoyed with the quality and/or I get to be a better photographer. Hopefully better technology and/or lower prices in 12 months will make my wait worth while - thoughts on that?
ok - I know that was tons of stuff, but maybe you can give me a quick general response - thanks in advance for your help.
