I've been trying different software and tests to try and tune up my LCD monitor (LG L1952TX). Tried Adobe Gamma, and some others, and settled on just using the standard sRGB ICC profile, along with hardware brightness and contrast adjustments. So far the tests at the link below have been most helpful.
http://www.lagom.nl/lcd-test/#gammacalib
Here are my results:
Quick Contrast
On the dark end, I can see a difference between bars 1&2 except for the red and blue. At the bright end, I can see a difference except for the blue where 31 & 32 look the same.
Sharpness test
At a distance not bad. My sharpness is set at zero.
Gamma 48%
Red - 2.3
Green - 2.3
Blue - 2.1
Grey - 2.1
Gamma 25%
Green - 2.25
Grey - 2.25
Gamma 10%
Same as 25%
Dark Levels
This one is fine. I can see boxes down to the first one.
White Set
This one is poor. Box 251 is the last one where I can see a checkerboard.
Have you, or are you willing to do these tests and post your results?
Ron
Quick Contrast
Sharpness test
Gamma 48%
Red - 2.3
Green - 2.3
Blue - 2.1
Grey - 2.1
Gamma 25%
Green - 2.25
Grey - 2.25
Gamma 10%
Same as 25%
Dark Levels
White Set
Ron
