Photoshop seems to take kind of a "harsh" approach to all of this
rather than a user friendly way of doing it.
In Paint Shop Pro, for example, if you're editing a 16 Bit TIFF and
want to save a JPG from it, you just choose "save as" and lo and
behold, right there in the list is JPG. If you then tell it to save
a JPG, it does the conversion from 16 bit to 8 bit for you "on the
fly" because that's obviously what needs to be done. And the beauty
of this is that you're still working with a 16 Bit file.
With PS, you must convert to 8 bit mode, make your save, and then go
into the history and revert back a step or two to get back to 16 bit
mode if you plan on continuing your work in 16 bit mode.
I find the PS way of doing it a bit "stubborn". It's as if they
won't lower themselves to just do what you want. Instead, they
insist on letting you know that they know that JPG is 8 bit, and darn
it, they're not going to convert it for you, you've got to do it
yourself because you should know better than to try to save a 16 bit
file to an 8 bit format.
I think they're just being difficult ;-)
Of course, there's always PS's "Save For Web" which does do the
conversion for you on the fly - but it removes the EXIF with no way
to tell it to leave it in place - unless you're willing to really go
the distance and use the "edit in ImageReady" feature. And now
you've spent ten minutes accomplishing what you wanted to do in
seconds when you started
Jim H.
