Gary Vrooman
Well-known member
I recently purchased the Cullman Magic 2 tripod and a black plastic sleeve (about 2 1/2 inches long) has fallen off it (it slid off the cylinder that contains the ball head). I don't see any mention of this sleeve in the owners manual, and there seems to be more than one way it could be put it back on (rotating the sleeve by 180 degrees, also the sleeve could be put back on either above or below the locking mechanisms). Is this normal or a defective unit? How should I put it back together and how do I tell when I've got it back together correctly? The metal cylinder that contains the ball head now slides out of the main unit and falls to the floor if the tripod is rotated after it is in its "packed up" (smallest size) state. I assume this should not happen once the sleeve is back on correctly, true? Does the sleeve lock in place somehow?
