Zorpie
Hello Guy,
I agree - 2500mAH from 1900mAH is not an insignificant increase in capacity. Tony said he was going to examine it in a little more detail when he found the time. But I just know that my own D2X battery seems to go on forever and would have expected at least the same from the D3.
I think the 3" LCD in the D3/D300 is of higher specification (as regards lower current drain) than the existing D2X version. But with LiveView and other extra menu intensive settings I guess maybe as a new camera then a lot of reliance is placed initially upon use of the LCD screen. (And probably a lot more chimping too) So maybe it is early days to assess how the older ENEL4 holds up.
I have a Jessops make ENEL4 (which is rated at 2500mAH) as well as two Nikon 1900mAH versions. Mind you - I also have two Quantum batteries (a 2 X 2 and a Turbo Z) I think I might also price the Quantum battery lead for the D2x/D3 rather than forking out on another ENEL3A as a backup. (If Quantum do such a thing that is)
Zorpie
If it seems too good to be true - then it isn't. If you cannot believe your eyes - then don't.
Zorpie
