Hi Pete,
I got my Ansmann fast charger from
http://www.fotosense.co.uk .
Look under Accessories:Other Accessories
ower. The Ansmann "Digi-Cam Power Set" (charger + 4x1800 cells) is the item at the top of the list, with the "Use Anywhere in the World" note.
Total cost is about £38.76 including delivery and VAT; you can order by phone or over the net.
Yes, I charge all my batteries, Energisers, GP and of course the Ansmanns with this charger. There is no reason why there should be any problem charging any make of batteries in this charger (so long as they are NiMH or NiCd).
Consider getting extra sets of batteries now if you need them, and you'll save the future delivery charge. I wish I had bought a set of AAAs to try out in my TV remote controls, they could save you a small fortune in the long run.
Just in case you don't allready know; the great feature of this Ansmann charger is that it will run off virtually any AC mains supply voltage without any adjustment, and is suplied with a set of four interchangable outlet socket pins, so you can use it in almost any country worldwide.
Other features: You can predischarge if you feel the urge (NiCds benefit, NiMHs apparently don't), and does AA and AAA sizes NiCd or NiMH in any combination 1,2,3 or 4 at a time. All four charging cicuits are totaly independant and can be started and stop at different times. Flashing LEDs let you know what is going on.
Its worth noting that the Rayovac 1 hour charger can be bought from Rayovac UK directly now for £29.99. It's faster but does not charge off any AC voltage or socket outlet, as the Ansmann does, and it only does AA NiMH not AAAs or NiCds. Also I'm not sure that it isn't designed particularly to suit the Rayovac batteries, of which the only include 2x1600s.
Hope this helps. Any other questions, don't hesitate.
Mark H.
