Hi guys,
Although I have been checking this site for years for several camera's, I have not been writing that much. I do have a problem with my new Nikon D200. Somehow I have problems with getting the correct white balance. Or at least, I think it has to do with that. I shoot lots of pictures at hockey games and my favourite teams has a very bright yellow jersey. I am only able to get this yellow quite correct by changing a lot of settings on the camera. I cannot say which settings came closest, but I remember changing White Balance, Tone compensation, saturation and hue. But when I do that, the faces of the players get a horrible color with brown/blue/red variaty. Shouldn't I be able to 'just' use the default setting and use white balance. I do use PRE White Balance and shoot a picture of a white object. I did have a D70 before and it used to work quite fine. Although my new D200 / AFS VR 70-200mm combination is perfect in speed for me, I almost started to feel sorry my D70 'died' two months ago. Can someone advice me? What could be wrong? If I check my pictures, most colors including white look fine .. just the yellow is horrible. I tried to shoot pictures at home (I collect jersey's) but it has the same problem.
Below first two pictures where the yellow is quite like it should be, but the faces are not that great in color. The third picture has really a good vesion of the yellow and because there is no face to see, it is perfect for me. Without changing all the settings and only change the white balance, you will get something like the fourth picture.
More pictures are available at http://www.raymondtellers.nl/icehockey . On the startpage look for the pictures of "Krefeld-Hamburg", "Krefeld-Nürnberg" and "Duisburg-Krefeld". Those have the 'yellow'-problem. There are more pictures of Duisburg, but the colors of them seem to be ok.
Thanks for any advice possible ...
