L
Lin Evans
Guest
Most of the lower resolution cameras have less of this problem. It's probably a combination of too many pixels on too small a CCD with optics which can't accommodate the combination. Even with the lower resolution cameras, it's possible to get this condition though not nearly as often. I've seen it on the Toshiba and also on my Sony D770 and D700 in certain cases. The better the lens, the less likely it is to see it, but even with Nikon's best lens on a D1, under the right conditions it's happened. When the D1 first came out, someone published a picture of a suspension bridge and there was a slight blue fringe where some of the guy wires met the sky. When you are dealing with a combination of red, blue and green filtering handled separately then combined, it's rare that everything works perfectly. There are many factors which contribute to the condition and if you know up front that it's likely to happen in high contrast scenes, you can minimize the probability by bracketing your exposures, or in the worst case, just put it into PhotoShop and handle it there.I have both a Toshiba PDR-M1 (1.5MPixel) and a Nikon 950.
The PDR-M1 displays absolutely none of the purple fringing effects
noticed in many of the 2 and 3 Mpixel cameras now available - so is it
due to the optics, CCD imager or a combination?
Lin
