--I find the same problem with the 580EX (not II). Under "External
flash func. setting: the following are grayed out: Flash mode,
Shutter sync. and FEB. And under External Flash Cn Setting, I get the
same Incompatible flash reading. And this occurs whether or not the
flash is powered on before or after the camera is on and before or
after the function is called for. Does anyone with the 40D and the
580EX find something different?
kdoc
What do you mean by that?. . .I also discover the old 580EX is not fully
compatable with 40D
I cannot set the 2nd shutter sync, anyone has any idea how do I set the 2nd shutter sync? I shoot a lot in 2nd shutter sync.What do you mean by that?. . .I also discover the old 580EX is not fully
compatable with 40D
Best regards,
Doug
Visit The Pumpkin, a library of my technical articles on photography,
optics, and other topics:
http://doug.kerr.home.att.net/pumpkin
'Make everything as simple as possible, but no simpler.'
I cannot set it either on my 580 EX (mark I.) !!I cannot set the 2nd shutter sync, anyone has any idea how do I setWhat do you mean by that?. . .I also discover the old 580EX is not fully
compatable with 40D
Best regards,
Doug
yess, thanks, i have alread corrected myself...Unless I'm not understanding what you are talking about it IS
available on the flash. Its a button has a H/> > > symbol next to it.
Press once for high speed sync and twice for 2nd curtain.
FEC can be set with the dial wheel. There’s a CFn setting that
remove the need to press the Set button first. Don't recall that CFn
but it's in the manual. I'm certain there a way to turn off the
flash itself and use only the AF assist. Note however you may still
see a pre-flash from the unit. I don't know for sure because I don't
use that particular feature.
Rob Kircher
My Stuff: http://www.pbase.com/rkircher
No need for the preflash to fire, there are two ways to do it.I just looked at my 580 and I think you can turn the flash off but
doing the following. Switch the flash into Master mode. Press the
zoom button until the 3 lines just in from of the flash symbol blink.
Roll the wheel until you see OFF. Press Set.
I believe that turns off the flash when the shutter opens, however
I'm certain you'll see a pre-flash.
...and think about side-effectsAgain, read over the manual to verify.
hmm, looks like that CF on the 40D will only work for the 580 II. Oh well, there's still the TTL hack...There's a CF on the body to set the camera to use the AF assist on
the flash but the not the flash itself.
