miemo
Active member
For quite a while now, I've been looking for a flat screen monitor to replace my old CRT for photo-editing and finally I decided on Eizo S2411W. It seemed to offer good enough color reproduction at relatively reasonable price. However, having now tested the monitor myself for a couple of days, I'm not 100% satisfied and I'd appreciate comments from other owners of similar Eizos, especially regarding the following behavior:
If I create a black-to-white gradient in Photoshop (using the gradient tool), there's quite clear banding visible in the gradient, i.e. the transitions between the tones are not smooth, and there's also hints of colors along the gradient.
However, if I save this same image as TIFF or JPG and view it on any non-colormanaged software, the gradient is displayed smoothly and without color toning. And again if I open the same image in any other colormanaged software than Photoshop (say ACDSee), the same banding and coloring issues appear again.
The only way to get a smooth gradient displayed in Photoshop, is to switch off color management - which of course is not a reasonable option in photo-editing.
The same issue persists if I use the pre-made default profile shipped with the monitor or personally created profiles (via Eye One calibrator). I've tried profiling with different settings in the monitor, but the results are basically the same with every variation. I've updated to the latest version of grahpic card (ATI Sapphire Radeon 9600 Atlantis) drivers and Eye One software.
To my understanding, this is what's going on:
Is this reasonable behaviour for a monitor of this price range (1000+€), or especially with this model of Eizo (S2411W)? Or could it still be some kind of individual hardware malfunction? I would very much like to hear someone else with the same series monitor to try out the gradient in Photoshop and let me know how it looks.
Of course I didn't buy the monitor just to view grayscale gradients, but I was really expecting that nowadays you could get a monitor capable of even that for a 1000€. But then again, I'm willing to pay a little extra just to know that the monitor I'm using is capable of passing this test as well (which in turn indicates something of the general quality level).
I'm very probably sending back this S2411W (thanks to 14 day return policy), and I've thought about the Eizo CE2411W as the next choice. It's pretty much the same monitor but with support for hardware calibration, which to my reasoning should offer a solution for the mentioned banding since the tweaks needed in the profile are done on the monitor with 14bits (instead of the 8bits on graphic card). But I would still love to hear from CE-series owners as well - how do your monitors behave with gradients in color managed enviroments?
- The monitor's panel in itself is of reasonable quality, and is able to produce smooth tonal transitions, since that is what I get when viewing the gradient in non-colormanaged enviroment. So we are not talking about lacking capabilities of the panel here.
- In colormanaged enviroment the gradient is displayed using the display profile which includes modifications done on the graphic card and these modifications cause the banding and coloring as a side effect. This is as such a known issue, but I wasn't expecting to see it in a 1.000+ € Eizo (which is among other things supposed to have a reasonably nice color reproduction, hence not needing that much tweaking in the profile anyway).
