CD/DVD Label
AndreTorng
Leading Member
Southern Calif, US
What kind of label do you put on CD/DVD? I'm afraid if I don't get it right and the label becomes loose, it will jam their Disk reader. Thanks for your advices.
  • Pro freelancer taking assignments in sports, concert and any events, especially fun assignments
  • Daughter asked Mom: 'Is dad a full time photographer now? Does he still have his old job?'
http://SoCalConcerts.PhotoReflect.com/
http://AndreTorng.PhotoReflect.com/
I use the Verbatim film dvds which have a little design that look like movie film on them, with just a small space to write - I write the couple's name with a calligraphy marker, and then 'wedding slideshow' on the other space... it works for me - no need to worry about labels peeling off or anything
http://www.instantphotos.co.nz
You can get CD/DVDs from even the best manufacturers with white, inkjet printable surfaces, silver inkjet printable surfaces, and even gold inkjet printable surfaces.
Epson, HP, and Canon (in Europe) have inexpensive printers that do a very professionale-looking job. My favorite software for the task is Acoustica CD/DVD Label Maker (www.acoustica.com), which is the best I've found, even at only a USD$29.99 download.
RDKirk
'TANSTAAFL: The only unbreakable rule in photography.'
The best solution for small-volume production is to use inkjet-printable discs. The best medium I've found are Taiyo Yuden CDs and DVDs with "Watershield" coating. This is a gel-type coating that is highly water resistant even with dye-based ink. You can hold it under hot water without smearing, whereas ink washes nearly completely off from standard coatings.
Round labels by Neat-O work well. They won't come off if applied correctly, and remain balanced. However, bubbles may appear if subjected to changes in temperature and humidity.
For higher production in a single color, look at thermal printers. There are a few left, but this technology is losing out to dedicated inkjet printers (with stack feeders).
It is relatively inexpensive to have blank discs silk-screened with your company name and logo. There's not a good way to customize these labels unless you use a suitable permanent marker.
Lightscribe discs are expensive, extremely slow to produce, and the same, ugly brown color throughout. The time factor alone kills this idea for me.
I do prefer the pictoral design versatility of inkjet printing to Lightscribe. Also, you can't get (as far as I've found) the top media in Lightscribe.
RDKirk
I have the lightscribe burner and hate it. Never use it any more.
I make labels for the case and use archival gold DVD with nothing written or printed on them.
Walt Roycraft
Walt Roycraft Photography
I had a CD / DVD labeler, created custom labels for my CDs, put them on and in six months they were unreadable. They would work in older, slower CD drives in my laptops but not the new, faster ones in my desktops. I had to reburn the whole bunch (and that's why it's important to back up your archive).
I got a lightscribe burner and use the lightscribe DVD media and it works great.
A printer that prints directly on the CD or DVD should be okay but I would never stick a piece of paper on a CD again.
jack
A few of my photos:
http://web.mac.com/kurtzjack/ or
http://www.sportsshooter.com/members.html?id=4177
Ditto on NOT using lables. We use to use them at work for about 5 years. Well we learned the hard way that some laptops with slimline CD/DVD drives viberate uincontrolllably with labels.
We also learned that the adhesive on some labels tend to cause problems later when trying to read old CD/DVDs, even after storing the media in an enviromentally controlled enviroment.
Best bet right now: inkjet printable media, inserts for cases, or writing on the media with a proper pen - but be aware the top of a CD or DVD is just as sensitive as the writable surface.
A DVD is not nearly as sensitive on the backside as a CD. In a DVD, the dye/reflective layer is sandwiched between two layers of polycarbonate. In a CD, the sensitive layer is protected by a thin layer of lacquer, which is susceptible to scratches and chemical attack.
I don't like to put a small labels on the CD/DVDs I produced because I suspect it may cause my customer problems. I do put labels on the jacket though. Your suggestions and advices have proven that my caution is warranted and I need to be careful putting labels on the disk.
i just bought the primera z1
(thermal printer).
so far it works, pure black and white but easy, waterresistant and fast.
I bought it in germany.
I do not know what US shops are reliable so I give you the link to the official shop:
http://www.primerastore.com/Signature_Z1
This printer can print on every CD without label, but its an advantage if the CD surface is blank ( usually silver ) so the printing does not get in conflict with things that are already printed on the CD.
Read the manual before using the device - its easy to use but for example without reading the manual you do not know that you have to press with your thumb into the middle to remove the CD. The manual is online here
http://www.primera.com/manuals.html
Agree with he 'no labels' posse here.
They look nice but more often than not seem to cause trouble. As for printable CD's, they seem OK but I would rather use them for DVD media than for CDs.
I don't put anything on the CD itself. I just print out a nice case design and stick it in the case. Never had a customer complain about it and if they did I would ust tell them I don't stick anythig on the media itself to ensure its longevity.
