Joey Camacho
Well-known member
Is it possible to use the on-camera flash and wirelessly control two SB-600 via SU-800?
D40
15-55mm EDII
55-200mm ED
SB-600
manfrotto tri 718b
D40
15-55mm EDII
55-200mm ED
SB-600
manfrotto tri 718b
The OP appears to be asking if the D40's built-in flash can be used in conjunction with the SU800. It can't. The SU800 will prevent the built-in flash from properly popping up.What? I'm pretty sure the SU-800 should be able to trigger SB-600's
without worrying about pre-flash from the on-board flash.
A sync cable, like the SC-28, will also block the pop up flash.If thats the case a sync cable can be use? Just exploring the
possiblties.
Here is another thought: if you really want to get into CLS wireless flash photography in a serious way, the D80 has almost the same wireless commander capabilities as the SB-800 built into the camera, using the pop up flash.Really what a surprise. Didn't even consider the su-800 not allowing
the built in flash to pop up.
More and more the SB-800 is the best choice.
I recently purchased a SB800 and a SB 26 to synch with my SB600. The SB800,IMOP,was worth my money. I needed to use all 3 flashes to fire simultaneously and thanks to the SB800,it worked flawlessly. It seesm like you already have 2 SB600s and there are about $70 price difference between the SB800 and the SU-800(if you buy the SB800 at ebay and I paid $315) and from what I read about the SU-800 is that it's not as reliable as the SB800.Really what a surprise. Didn't even consider the su-800 not allowing
That setup gives a good, simple master / slave setup.I used the SB600 as the master flash on my D50 and SB800/SB26 as a
slave.
I highly recommend the SB800 if you want to do Nikon CLS.
For my shooting style,a TTL wouldn't work for me because of the SB26. You'd need to use manual mode in all flashes. I just needed to use 3 flashes wirelessly and to fire at the same time and it worked perfectly. I wouldn't call it CLS.That setup gives a good, simple master / slave setup.I used the SB600 as the master flash on my D50 and SB800/SB26 as a
slave.
However, a true TTL CLS setup with a D50 (or D40) would require the
SB-800 to be used as the master, and one or more SB-600 or SB-800 as
the slave(s). (The SB-26 is not CLS compatible)
