K10D Inishowen Seascape
Cheers for that.
This is the Pentax 14mm DA on the K10D.
Shot with a tripod and 2 stop ND grad filter.
Released by remote control.
Andy
Thats a brilliant shot, so surreal. The water looks like velvet. What shutter speed did you use?
Thanks,
The first is 1.5 seconds.
I usually try to keep my sea shots below 2 seconds. Anything longer and it does tend to mist out. I like the misty effect too but I prefer to keep some wave definition to give a feeling of flow.
Andy
Another great series of shots Andy. I reckon one benefit of the unsettled weather is some spectacular sunsets, almost Autumnal.
Terry
Wow, great shots Andy. Do you have any tips for using graduated neutral density filters. Sometimes, even if I use a 3 or 4 stop during a sunset, the sky still gets washed out.....
Cornee
Cheers Cornee
Using my Lee filters, I find that 4 stops is the maximum I would go to. Anything stronger tends to give a very un-natural result with a slight cast.
If the foreground is still very dark using higher strength grads then I would recommend dodging the foreground in post process. There will certainly be plenty of detail in there that you can bring out (something I could never do with Velvia!). Just make sure to get your sky exposure spot on.
Shooting into the sun is always going to be highly challenging. You'll need those high strength gads and you will also have to make a decision as to how much sun clipping is acceptable. Then you've got flare to contend with too.
It gets easier when the sun dips down and sometimes clouds or haze can help control the contrast.
Hope that helps.
Andy
http://www.skyandstone.com
Very nice Photo!!!!
Those colours are just perfect, so relaxing, I can almost hear the water running over the stones...
Perfect in every way, thanks for sharing this!
Neil Vanderwolf
Zenfolio Featured Photographer
http://thewarmland.com
