Which 50mm (or other)
asyouare405
Active member
Hi,
I've decided that my 18-70 lens just doesn't have a low enough f/stop for me, so I was thinking of getting some other. Based on the photos I've taken so far a 50mm fixed would cover most of the pics i've taken so far. Which lens would everyone recommend? I seem to be doing a lot photos in museums so I think 50mm would be good, right?
For lower light shooting, you could try a 50/1.7 ($100ish, probably less) or a 50/1.4 ($200ish), they are both nice lenses and produce good results. A bit wider is the Sigma 30/1.4, but also costlier.
-Kathy
Hi,
The other member got the lenses and price ranges right, I went for the 50mmf:1.7 and it is very sharp.
You need to ask yourself what you want to do because this lens is effectively a 75mm and should make for excellent portrature, a 28mm=42mm which is much closer to the true Normal angle lens. 20mm=30mm and closer to wide angle than super wide. If available light is what you want then the f:1.4 is the fastest I have seen available so for.
Paul Cassidy
Portfolio: http://actiniclight.smugmug.com/
. . . dragons in the pasture!
Most of what I do is take photographs inside museums. In the NYC area I'm lucky enough that some of the bigger museums let you take photographs for personal use, but don't let you use a flash. I'd say the available light is normally on the darker end what people would consider normal indoor lighting.
Sounds like you may need a Sigma 1.8 lens. Comes in 20, 24, and 28mm flavors. Or the 30mm 1.4 mentioned.
Greg
Using your kit, you will be able to guess which focal length suits your needs best. If it's indeed 50mm then both the Min 50/1.7 and the Min 50/1.4 are very good options. For photographing rectangular objects (such as paintings) you will also wish to have a lens without significant (barrel) distortion. This is usually less of a problem with the longer lenses such as the 50's and more of a problem with wider lenses such as the above-mentioned Sigmas (20, 24, 28). In sum, if 50mm is the right focal length your problem is easily solved.
Cheers, Maurus
http://www.pbase.com/maurus_e/
I love my little cheap Minolta that I bought on Ebay for $85.00. Low light, no problem !! Snappy and quick.
Here is a little example.
Michele
Sony Alpha 100
Carl Zeiss® Vario-Sonnar T* DT 16-80mm f/3.5-4.5 Zoom Lens
Sigma 70-300mm f4-5.6 APO DG
Minolta Normal AF 50mm f/1.7
HVL-F36AM Flash
http://www.pbase.com/michelep
I remember i was looking a while ago at the forum and I can across thread that mentioned that some of the 50mm lenses are prone to a blueish area in the center, which ones?
Just to confirm i understood you, at 50mm the barrel effect is minimal where as at lower sizes it is noticeable?
