smhagger
It sounds like you've got some great equipment to get you going. I would definitely recommend a backup body (at least a d-Rebel, just so that you have something in case your 5D goes down in the middle of a wedding). Better yet, if you can swing it financially, pick up another 5D, 30D or Mark III and plan on using it in parallel with your 5D (24-70 on the 5D, 70-200 on the other body).Thanks again for your detailed info and your willingness to help,
Sean. And for the link to that pdf file. It's very useful. Appreciate
it a lot.
Wow, that's a lot of equipment All I got is a EOS 5D body and 24-70L
and 70-200LIS lenses + 580EX Speedlite. Obviously, one more body and
one more flash is the must, let alone light stands and backdrops. My
head spins from all the essentials you listed)
I'm not sure that I would put the lightstands and backdrops on your short list of items to purchase. I would talk to your clients and find out if this is something they want, and when that time comes then pick it up (early enough to practice with it and learn the setup to be prepared for when the real day comes).
One accessory to get--if you don't have 1 already--is a Expodisc (portrait), Expodisc, or Whibal WB card and preset your White Balance (I think it's called 'custom' white balance on Canon cameras, instead of 'preset' on Nikons). This give much better results, sets the colors great, and greatly reduces post-process time.
BTW, I always shoot RAW--just in case. If everything turned out great in the original shot, then it's a simple batch conversion to jpg after embedding copyrights and a little sharpening.
Only during the entrance and after the kiss / presentation. Having said that, I'm beginning to shoot more available light throughout and am enjoying the nice results that I'm getting without using flash. I guess you should get comfortable shooting either way. I'm still working on learning to 'see' light to get better results. Flash seems to give too 'flat' of lighting, but it does make the colors 'pop'. Natural lighting really gives a more romantic feel to the images.No doubt, artificial lighting is crucial when you shoot indoors.
Lighting is a topic of personal taste and a lot of debate. Hang around here and observe the different setups that some of the more experienced shooters use. There are times when I feel flash is mandatory--like during my last wedding under the harsh direct (2 PM) sunshine with no clouds and no shade whatsoever. I used fill-flash to reduce the harsh shadows, but tried not to overdo it with the flash. To make matters worse, the groom and groomsmen all wore white tuxes! After the wedding was over, I ordered up 3 B+W 3 stop ND filters to give me better control over the lighting next time and dial in the optimal settings so that I don't blow as many highlights (although it will be inevitable to some extent under these conditions). This is where the Fuji S5 Pro will really earn it's keep. It does an amazing job of allowing proper exposure without blowing highlights due to its greater DR.I
wonder if you use any apart from your flash units. If so, what are
those? And what kind and brand of light stands do you use for your
flashes or other lights? I know there's a lot of lighting equipment
out there but it would be nice to hear about what is actually being
used and how practical it is in the settings of a wedding from
experienced photogs such as yourself.
As much as possible, I try to 'pre-meter' the scene and dial in a manual exposure mode on the body. The Sekonic gives the best results and ensures correct exposure, optimum detail, minimal-to-no noise and makes life much quicker in post process. I didn't follow my own advice during my last wedding and I'm really paying for it in post process time right now (I should have pre-metered and shot in Manual, instead I used the matrix meter (which did great) and aperture priority). I was a little distracted this past wedding as I allowed another individual to assist me whom I never worked with before. I thought he knew more about photography, but it turns out he was lucky to know which direction the lens was pointed! Never again...Also, do you really need a
light meter in that fast paced environment? I thought it was just for
studio work.
Glad to help.Thanks again,
Serge
Sean
