mrgjlg
New member
I want to see if anyone else has experienced this with their 18-200 VR. At the wide end of the zoom – about 18 to 35 mm, it just won’t find and lock focus most of the time. Right at about 35 it tends to lock focus, but not necessarily always – beyond that it’s ok. I’ve tried every mode, including: with and w/o VR, AF-A, AF-S, AF-C, single-spot focus or multi or dynamic – focus light on or not – it happens in both broad daylight and indoors with varying light. It usually doesn’t even attempt to hunt. If I zoom in more on the same subject, then it starts to focus OK, though it’s sometimes slow-ish to do so. It doesn’t matter what the subject is or how much detail it has – and I make sure that the focus point doesn’t cover objects at varying distances, no mirrors or confusing patterns, etc. I’ve jiggled the AF/M switches on the body and lens. In this situation, sometimes it won’t focus at all, and sometimes it finally locks after 5-15 seconds. Out at about 50+ mm it focuses much better. At 18 mm, if I stand within 6-10 feet, it starts to work – but for that same subject, if I step back some it starts to fail to focus. It’s as if it wants the subject to be “large” under the focus point. I have also tried a complete reset of the camera. It's never been dropped.
Under the same conditions and settings and scenery, if I put on my only other AF lens, a 35-135 Nikkor, it’s always focuses ok – but then again, that setting of “35” is that border line where it seems ok on the 18-200.
From this, I couldn’t be sure if it was the body or the lens and neither could the Nikon tech on the phone, though it seems like the lens. So it’s going in for repair.
