1) Need a faster shutter speed. Bump ISO to 400 and that will help. Is your monopod technique good?Here are the technical details
First Pic is
Iso 200
70 mm 1/125 sec
f/2.8
matrix (5)
second pic
Iso 200
200 mm 1/320 sec
f/2.8
matrix(5)
John is right. With f/2.8 you have very little DOF, you need to stop down to at least f/5.6 maybe even f/8.1) Need a faster shutter speed. Bump ISO to 400 and that willHere are the technical details
First Pic is
Iso 200
70 mm 1/125 sec
f/2.8
matrix (5)
second pic
Iso 200
200 mm 1/320 sec
f/2.8
matrix(5)
2) You may have mis-focused with the first one.
3) Try stopping down to f5.6 or so. Not every single image needs
to have background separation. It is sometimes difficult to get
background separation when shooting a group.
JohnE
Equipment list in profile
Many of the newer lenses lost their scale when the A ring went poof!Thanks to all for your reply this is a big help!
But next question is how can I determin DOF with digital camera
and lens?
I know ther used to be a DOF scale on those lenses. But this is
gone nowdays??
First Pic is
Iso 200
70 mm 1/125 sec
f/2.8
matrix (5)
second pic
Iso 200
200 mm 1/320 sec
f/2.8
matrix(5)
JohnE
Your D200 has a DOF preview function. Yes, the viewfinder will darken, but you can probably get a quick idea by checking the sharpness of subject edges.Thanks to all for your reply this is a big help!
and lens?
gone nowdays??
It's easy if you don't shoot raw... give me a break!both are blurry, white balance is off (hence the color), because
you were in the shade so you need to warm it up a bit (easy if you
shot RAW), and you cut off eveyone's feet?
that is a bunch of bs!I guess advice is, shoot RAW, bump up ISO if your shutter speed is
too slow to handhold or hold on monopod and watch the composition.
is your camere on auto color or daylight??and the color is easilly fixed in any imaging editor just add yellow and it looks much better..
