Good question! Good discussion with some great answers...
To Tim:
97% believe the urban myth that dSLRs have fast shutters. It’s not true. They have SLOW shutters and FAST AF. Cameras with no flopping mirror, have SLOW AF and FAST shutters. When you add the AF lag to the shutter lag, cameras with mirrors win, but not by much! In the past few years, non-mirror cameras have improved a LOT…at least the best ones have. There are still a lot of really slow AF cameras out there! But a blanket statement that non-dSLRs have slow AF is not true anymore. Read the reviews.
ALL cameras can be used in a P&S mode. Point & Shoot is a lifestyle, not a type of camera! Point & Shoot simply means the photographer doesn’t care enough about getting better pix to take the camera out of Automatic Mode…it means nothing more. dSLRs have quite good Automatic Modes and most entry-level dSLR owners use it more than the other modes. Also, implying that I have 2 P&S cameras is an insult! I have never use the Automatic mode on either of them. Ever.
ALWAYS pre-focus, regardless of the camera. To not pre-focus is wrong. That’s the way DCs are intended to be used. That’s why virtually ALL cameras have a half-press detent in the shutter button.
To Lejay:
I strongly agree with you that dSLRs vs P&Ss is a mixed metaphor. But a better counter-analogy would be comparing SUVs to automobiles…or apples to fruit.
And your point about P&S being a style of photography is dead on accurate…and much mis-understood!
All other points were very good, but I’ll disagree with your characterization of phase detection AF as being fast and accurate. dSLRs have a small but persistent problem with AF accuracy. The reason is that there are two sensors involved: the ones that facilitate the AF, located up in the pentaprism roof and the primary sensor that captures the image. These must be ALIGNED relative to each other! You’d think that would be a one-time adjustment, but unfortunately for complex optical reasons, some lenses tend to focus differently. Serious photographers occasionally have to “select” lenses that focus the same in order to get consistent AF with their dSLRs. Prowl the dSLR forums and you will see a few of these discussions. Cameras with contrast AF use the same sensor for both functions; if designed properly, they don’t have an accuracy issue.
To Ken:
The issue of which is the best learner cam, is bit like the issue of whether it’s best to learn to drive a manual shift or auto shift car. There is no correct answer. It depends. You learn different things first with each approach.
To John:
Big cameras tend to have better “layouts” for the photographer, as they have space to put more buttons. The tendency to miniaturize everything results in terrible ergonomics and arcane menus.
I’m an advocate for “good” EVFs. I find having live preview, live histogram, and live over-exposure indication absolutely invaluable! I’d like a dSLR, but I want one w/o a @#$% mirror! I want an EVIL camera!!!
Except I’ll find a better name than “EVIL”… ;-)
Charlie Davis
Nikon 5700 & Sony R1
CATS #25
PAS Scribe @
http://www.here-ugo.com/PAS_List.htm
HomePage:
http://www.1derful.info
'I brake for pixels...'
