DavidMillier
I don't see how temporal aliasing is a problem with a stationary subject. It's good enough for astronomers.
Scanners
Galleries and website: http://www.whisperingcat.co.uk/mainindex.htm
Scanners
--Of course it is a means to an end. As you indicate the VFAWhy do you think the vertical design makes a difference, I'm curious.
The difference between Foveon/scanning back and Bayer is the lack
of a CFA and AA filter. This means no loss of sharpness approaching
Nyquist and a lack of colour aliasing because of the alignment of
spatial and colour detail and losing the requirement for
interpolation. The vertical array bits is simply a means to achieve
this not an end in itself...
contributes
"a lack of colour aliasing because of the alignment of
The need for interpolation occurs because the CFA model cannotinterpolation."
record the full color spectrum at any x,y grid point. To do that
you need the z axis, the vertical postioning of the B,G and R
"sensors." The Vertical placement allows you to gather full chroma
and luma data at each x,y point without interpolation. I think that
is a significant factor ad I cannot think of any other way to do it
(the designs that "rotate" filters in from of a sensor (and rotate
can be accomplished lectronically, not really tiny wheels,
introduces temporal aliasing). If you can I would love to hear how
it can be done.
Pete
