Duane Kuenstling
Active member
I see this all the time but don't understand what it means.
Four/thirds is a ratio, with the image being 4 units wide by three
units high. Why do I say units? because the ratio is the same no
matter what the units are. Remember the '645' format? (Minolta,
Contax, Pentax, Mamiya & others) it is the same ratio. But the
dimensions were (are) 6 cm by 4.5 cm. So, the shape of four/thirds
is exactly the same shape as the earlier and still used 645 film.
In addition there have been sheet film of 3 inches by 4 inches and
sheet film of 9 inches by 12 inches. Same ratio. (Personally I like
this ratio better than the 35mm ratio.)
The Oly sensor doesn't measure 4/3rds of an inch, not according to
the chart you posted earlier. No dimension of the sensor measures
4/3". Not the horizontal, the vertical or the diagonal. Take the
lens off your Olympus (assuming you have one) after locking the
mirror up and look inside.
Danny,
18 x 13.5mm is a ratio of 4 x 3 (divide 13.5 by 3 and multiply it
by 4 and you will get 18). It is not a measurement in inches. The
fact that the lens is measured in millimeters makes that clear.
I was not making a wisecrack and my reading comprehension is pretty
good, I believe.
The 4/3" is a measurement, IN INCHES, of the OUTER diameter of the TV camera glass tube, of which the actual imaging plane is 2/3 the size.Danny,
good, I believe.
Richard
Most of the answers just talk about the ratio, but in terms of this camera series it also means the lens mount, the format, the whole standard created by Olympus and Kodak. See this site for the WHOLE story:I see this all the time but don't understand what it means.
--anyone happen to know the size of Canon's APS C as in XTi ?
Riley
not all that counts, can be counted
Olympus DOES say:...4/3 is the diameter of the projected image circle espressed as
an improper fraction of 1-1/3".
