atigun
Leading Member
A while ago while doing some moonlight/aurora exposures with my D200, two exposures following each other showed these concentric artifacts. They were exactly centered in the frame. The camera was moved and aperture was changed between the exposures (I was doing moonlight exposure at medium aperture and then the aurora showed up. I forgot to open up the lens on the first exposure). Both were in aperture priority which maxed out at 30s with long exposure noise reduction on. No images taken earlier or later under similar conditions have showed these.
Link:
http://www.photo.net/photodb/photo?photo_id=5806306
Go to "Larger" which should give you a 100% crop. Processed and cropped in Capture NX.
I doubt I will ever see this again, however because of another ongoing thread describing a "rainbow effect"
http://forums.dpreview.com/forums/read.asp?forum=1021&message=22716413
(middle image) I thought it was a point in posting it.
It is pretty clear that in my case it is not a pixel level artifact. In both cases the rings comes closer and closer together towards the periphery.
Link:
