Announce: Linux - GIMP Dimage color plugin 1.0.0
Laurent Houdard
New member
Paris, FR
This GIMP plugin converts Minolta DiMAGE 5/7 JPEG pictures to sRGB colorspace.
You can download it at:
http://l.houdard.free.fr/dimage/gimp-dimage-color-1.0.0.tar.gz
In my tests, the converted images look exactly as if they were converted to sRGB by the Dimage Viewer utility.
What the plugin does is:
  • a "standard" colorspace conversion, and
  • a tone correction based on a curve found in the ICC profile as a non standard tag ('iTRC').--Laurent
colorspace.
This is GREAT news!! The only thing is, Mandrake doesn't list the Minolta Dimage as a supported camera. Where have you found software to hook up the USB and get the images onto the computer? This is one of the few things holding me back from converting to Linux at home. I dual-booted hoping Linux had caught up enough for me to use it, but it appears it can't do it yet. My scanner is not supported, either, evidently. My PC shouldn't be the problem. It's a one-year-old Micron.
Mark A. Williams wrote:> > Where have you found software to hook up the> > USB and get the images onto the computer?> > I'm using a SanDisk USB compact flash card reader (ImageMate> SDDR-31), but some people have succeeded with a patched kernel (see> "Dimage 7 usb driver for linux" thread in this forum).> > --> Laurent
I use a Pyro firewire flash reader. It's fast and doesn't use any camera battery power.
Is there any advantage to using the camera directly?
Bradley
P.S. Anyone know why my quoted messages don't contain any newline (unless I put them there)?
Apologies if this is a stupid question Laurent, will this plugin work with the windows version of GIMP?
Luke
That's great news!! I have the SanDisk SDDR-31 as well. Now, how did you get drivers to make it work? I'm using Mandrake 8.1, so that might be different from your distirbution.
P.S. I'm not a programmer. I want to use Linux so I can get away from unaffordable software. So, if it requires programming knowledge, I probably can't do it.
Hi Mark!
The SDDR-31 is not really a problem, you have to make sure you have SCSI-support in your kernel (with support for SCSI disks)
Besides SCSI support you will need USB support for your USB chipset and the USB storage driver. As you are using Mandrake, they are probably precompiled for you, so you just have to (as root):
  1. modprobe sd_mod
  2. modprobe usb-ohci (or -uhci if you have an Intel chipset on your motherboard)
  3. modprobe usb-storage
Now you should be able to mount it from dev/sda1 (assuming you don't have any other SCSI disks)
Gtnx
Marcel
  1. modprobe sd_mod
motherboard)
  1. modprobe usb-storage
Gtnx
Marcel
I didn't get Linux because I'm a programmer, so all this stuff gets a little frustrating. If it really was as easy to do as so many people say, then it would have given Windows some real competition by now. Anyway, I will try what you suggested. Thanks a lot for the time you spent typing all that. Handholding is what I need.
Hi!
by now.
Well, most things Windows can do automatically for you are also possible in Linux (at least in the friendlier distributions, like Mandrake), but those are things most people do daily, such as word processing/spreadsheet work etc..
For most other things, you will still need a bit of knowledge about the way Linux works and why it works that way, but the same is true for quite a lot of problems I have been asked to solve on Windows-systems. The difference between the two is: with windows you are advised to call your 'system administrator' to fix it for you, and with linux you are your own system administrator (not a programmer, mind you, these are two distinctly different fields, although most people in one field also know a little bit about the other).
What I actually mean to say is: while Linux may require you to learn quite a bit more than Windows, you will gain a lot of knowledge and satisfaction from knowing your system, which you can also apply in a lot of other situations.
That's ok.. And for the handholding: everybody needs that sometimes, especially when plunging into the deep :-)
Gtnx
Marcel
PS. This is getting quite off-topic, so if you still have trouble it may be better to e-mail me, although I can't guarantee a quick response...
