AmitC
Well-known member
You mean best at 10 or 20 but soft at around 14?
Gromsky, did you follow the earlier (extensive) set of tests done
by kocho on his Sigma 10-20? He found softness about 1/3 of the
way from the left of the frame at 14mm. Take a loot at this shot
of mine at 10mm:
http://www.pbase.com/amitc/image/75369640
If you look at the shingles on the roof that are furthest back, you
might notice that the ones more towards the left are blurrier than
the ones further to the right (even though they're the same
distance from the camera!). You'll notice the same thing with the
sharpness of the tree branches that are right in front of those
shingles. This was even taken at f/8, which should give good DOF.
Am I just seeing things?
Yes, but I didn;t mean soft, softer maybe.You mean best at 10 or 20 but soft at around 14?
Yes, sigma warranty sent me a replacement lens for the one I sent-in. What they got me that time was the worst sample. So off it went back to them and I explained how to test one before sending it to me. This way the fourth one came OK. It was sharp edge to edge, except wide open in the extreme corners. It still had some of the soft strip thing but that I did not mind that much - got tired, plus when resized for web it would not show at all, so no issue for me. I had to sell that one a few months ago as I needed to raise some cash, so unfortunately don't have new samples to share with you.Do you think the blurriness you see in the trees is the kind that
would make a difference at 8x10? I followed your experiences with
Sigma very closely and am reluctant to get into that whole
roulette, even though I really like the 10mm focal length.
By the way, I thought you fourth lens was sharp edge to edge,
correct? Was that after a repair or a replacement by Sigma?
Hope you are well. Thinking about this again, I went and looked at my old Tokina 20-35mm 3.5-4.5 AF and it does a little better with the lens markings, it gives indication with a line for 20 and 35mm plus the standard focus line, which I assumed was for 24 and 28mm settings. Here is a picture of that lens.Wel that sounds great on paper, BUT in real life.
What you suggest is impossible to put into practice.
Here is the focus scale on the Sigma 10-20, somewhere along that
line is infinity, so it is not that simple.
[snip]Yes, before someone mentions it.
I did factor in the crop factor of 1.5 on the D70 when calculating
for hyperfocal distance.
You are correct in stating that a 20mm is a 20mm no matter what crop factor.The crop factor only effects field of view (FOV) not DOF or focus.
