Amnon Duvdevany
Member
Hello,
B&H store have both KM and Sony 24-105(D). The Sony costs about 100$ more (about 430$ instead of 330$). Looking at the specs there are some differences (if cited correctly by B&H):
1. Minimum stop range - 37 for KM (?), 27 for Sony.
2. Minimum focus distance - 1.6' for KM, 1.7' for Sony.
3. Weight - 448 gr. for KM, 395 gr. for Sony (Why?).
Looking at the photos, they have different zoom/focus rings.
Regarding the optics (the most significant issue of course) it seems they are the same - 11/12 groups/elements, 2 aspherical lens elements, circular aperture, non-rotating front...
Any significant differences? Any reason to buy the Newer (and more expensive) Sony version?
Thanks.
Attached hereby are the features:
KM:
The AF 24-105mm f/3.5-4.5(D) is a compact standard zoom lens that offers an exceptional range. It provides excellent focusing operation and high-quality images throughout the zooming range.
During autofocusing, photographers can easily hold the camera in good balance thanks to Minolta's Auto Clutch Mechanism, which does not rotate the focusing ring during AF drive. There is no need to operate any switch to activate the mechanism. In manual focusing, the wide, well dampened ring is easy to control and rotates smoothly. The three aspheric surfaces (in two elements) reduce the total number of lens elements and thus shorten the length of the optical system. Optimally arranged, these aspheric lenses reduce spherical aberration, sagittal flare and coma. The result is a super-compact lens with high-quality images throughout the zooming range. In addition, this new lens features a circular aperture diaphragm for beautiful rendition of defocused image areas.
In combination with the Maxxum 7 (or newer cameras), the AF 24-105mm f/3.5-4.5(D) supports the ADI (Advanced Distance Integration) flash metering, by providing precise distance information utilizing its built-in distance encoder. Highly accurate flash-metering performance is obtained.
This lens comes standard with a large, petal-type lens hood for optimal light shielding.
Key Features
• Ultra compact 4.3x zoom lens
• Wide focusing ring for comfort and better control
• Non rotating front during Autofocusing
• Support Minolta's ADI (Advanced Distance Integration) flash metering.
(Minolta's new "D" lenses feature Distance Encoding that provides refined multi-segment metering for manual focus operation and depth-of-field display on Navigation Display with the Maxxum 7 as well as ADI flash functions with the new 5600D & 3600D flashes.)
Sony:
The Sony SAL-24105 24-105mm f/3.5-4.5 Lens is a compact standard zoom lens that covers the zoom range most often used for general-purpose photography. It provides excellent focusing operation and high-quality images throughout the zooming range.
During autofocusing, photographers can easily hold the camera in good balance thanks to its Auto Clutch Mechanism, which does not rotate the focusing ring during AF drive. There is no need to operate any switch to activate the mechanism. In manual focusing, the wide, well-dampened ring is easy to control and rotates smoothly. The three aspheric surfaces (in two elements) reduce the total number of lens elements and thus shorten the length of the optical system. Optimally arranged, these aspheric lenses reduce spherical aberration, sagittal flare and coma. The result is a super-compact lens with high-quality images throughout the zooming range.
Key Features
• Ultra-compact 5x zoom lens
• 2 Aspherical Lens elements to correct aberration
• Non-rotating front during autofocusing
• Circular Aperture for pleasing defocused effects
AD
Thanks.
KM:
Key Features
Sony:
Key Features
AD
