Zvio
Forum Enthusiast
After three failed attempts to get a coherent answer, they finally came up with this "answer"... Let's see what the forum members think of that:
Dear Sir/Madam,
Thank you for your enquiry.
The use of old K-lenses is restricted on d-SLR cameras!
There is no fix because this is related to the construction of those old lenses.
Metering using the green button will only work correct when having the aperture fully open.
These lenses do NOT have the required electronic contacts to transmit the aperture opening to the camera.
I hope that your question has been answered to your satisfaction.
Should you have further questions regarding this matter, please do not hesitate to contact us again.
When replying, please make sure this email is included.
With kind regards,
Wim van Kleef
Pentax Digital Camera Support Team
Your Email:
[Hide Quoted Text]
Dear Sir/Madam,
With kind regards,
Wim van Kleef
Your Email:
[Hide Quoted Text]
I am working with the M-mode and, of course, have set theMember said:Your Email:
Dear Sir/Ms,
No, the problem I reported did not go away! Here it is once more:
I own 5 pentax cameras starting from the MX through *istD and now
K10D. My 5 M-lenses that still work perfectly on the *istD do not meter
as they should on the K10D; Specifically, the metering is OK when the
aperture is fully open but when stopping down the metering reading
(upon pressing the green button) causes consistently overexposure on
all 5 lenses.
Member said:"A-ring" option to enable shooting with these old lenses...
This problem exists also in many other K10D as reported in the Pentax
Forum on Dpreview. We all urge you to find a solution!! Check out the
Dpreview Forum, and let me know if you need help in that!!!
