IrfanShariff
Member
We normally shoot JPEG's and not RAW, so if the sharpness is bad in JPEG what makes K10D a better one, apart from ergononmics, SR and other features the final output should(picture) should be good right?
Who told you that the K10D has a sharpness issue? Read the manual and it will tell you that if you want to print straight from the camera then set the camera to "Bright" mode (page 120), if you want really sharp then set sharpness to +2 (page 121). Easy if you read the manual. While you are at it make sure you read a bit about SR, it will not work so well at short distances (page 69), turn it off or move back a bit for best results.We normally shoot JPEG's and not RAW, so if the sharpness is bad in
right?
"So, when did you stop beating your wife?" is the archetype of a technique demonstrated in your "question".We normally shoot JPEG's and not RAW, so if the sharpness is bad in
right?
The only reviewer I am aware of who thinks that K10D image sharpness/detail in default JPEG (without using Bright or sharpening) isn't up to other 10mp models is Phil Askey of this site and he says that is indistinguishable difference up to A3 prints.We normally shoot JPEG's and not RAW, so if the sharpness is bad in
right?
Who is "we"? Certainly not me...We normally shoot JPEG's and not RAW
better than what? The features you list below make the K10D a good camera.so if the sharpness is bad in
Daveapart from ergononmics, SR and
right?
the answer is very easy, You don't buy a 10 Mg pix camera to shoot JPGE simply beacuse it wouldn't make sense. To make small-medium sized copies you shot 4Mg or 6 Mg and that 'd be fine, even better than 10 Mg and much easier and quicker to handle and modify with you computer.We normally shoot JPEG's and not RAW, so if the sharpness is bad in
right?
The review here instilled the same doubts in me. The guys and girls from this forum here removed them again (thanks a 1000x over!).We normally shoot JPEG's and not RAW, so if the sharpness is bad in
right?
Right!We normally shoot JPEG's and not RAW, so if the sharpness is bad in
right?
If you personally (not because how you intrepret what Phil told you) consider K10D JPEG sharpness "bad" for your personal usage (no RAW and no PP), size of prints (bigger than A3) and IQ criteria then nothing makes K10D "a better one" except things that you listed above.We normally shoot JPEG's and not RAW, so if the sharpness is bad in
right?
Guys before telling anything just check the full review of K10D in
this site itself and compare the samples with other 10MP camrera
and especially read the conclusion-cons it clearly states my point.
I love your cat images what settings did you use regards Alan.
