I have the same printer as you do. I have great success with the
following setup. Email me direct if you have further questions:
[email protected]
Thang.
Printer settings:
1. I recommend you to do everything through your PC w/ Photoshop LE
(came along w/ your camera) or Photoshop 6.0.
2. Download 2 ICC profiles for Epson Color Life paper (1440 and
2880). Go here:
http://support.epson.com/hardware/printer/inkjet/pho785/index.html
3. Set these up in your PC. This is the most important and can be
confusing part. Make sure that you have both of the above files in
the Properties of your 780. Go to start (in Windows), setting,
printer, 780, properties, color management tab. The box entitles
"Color Profiles currently associated with this printer" should have
something like "SP780SP785COLORLIFE2880DPI" and "1140"...Then,
check on "automatic".
4. When you are in Photoshop and ready to print, this is what you
should do
a. File, print, at this window, "print quality" should be high,
"print as" should be RGB
b. Go into setup, properties, at the "main" tab,
c. Media type should be "photo quality glossy film"
d. Ink – “color”; mode – “custom”;
e. Click on "advance", check "photoenhance4", tone should be
“hard” or “vivid” , effect should be
“sharpness”, and set at "high". Print quality should be
either “1440” or “2880”.
f. Click ok. Now you are back at the "main" tab. Click on print
preview. Click on paper tab
g. In paper tab, just click on the paper size that you want, then
click ok all the way through. In this screen, you can also set your
own paper size under the “User Define” option.
h. Photoshop then will do the print preview for you. If you like
what you see, then click print. If not, go back and adjust whatever
you need to adjust. Play around with these settings and others to
find out what you like best. You can also change the brightness and
contrast of the picture through Photoshop and it will show up in
your print as well. However, you need to change at least 10
"increments" before you can see the difference in the printout.
Have fun.
How do I use the ICC profile for Epson Colorlife Photo Paper which
I just downloaded from epson web page. I downloaded the one for my
Epson 780 . I have Photoshop Elements. Do I install it somehow into
PS Elements? Help please.
