Brett St Pierre
.. it occured to me that a number of (generally newer to Pentax, but not always) people are complaining of under exposure with their 360 and 540FGZ flashes, I don't but I use the Sigma EF 500 DG Super so assumed it was that. Then tonight I was reminded of the fact that I use a Sto-fen OmniBounce on my flash virtually 100% of the time - it has the effect of flooding more light around the room and when bouncing (use this position outdoors for fill flash) it at least partially fills in the shadows that would otherwise be effected from bouncing off a ceiling.
The other effect is it reduces the chance of under exposure, at least with the EF 500 DG Super. Why? I am not sure if it is affecting the Pentax P-TTL system to give a different reading or if its because the Sto-fen forces more flash power it throws light in other directions, filling the room - some of which is wasted.
I am not saying this is THE answer, just an idea people might like to try to get a different result from their P-TTL flash. http://www.stofen.com/
The following is not are (no kidding!) - just a couple of examples, one more extreme than the other (I can prove it over and over again but sometimes up close the Stofen gives over exposure - often I have to pull the exposure back a bit but that is easier then the opposite). See the way light is filling in under the toy garage with the Sto-fen even though it is bounced of the ceiling.
K10D + EF500 DG Super - Bounced but NO Sto-fen
With Sto-fen (arguably over exposed)
No Sto-fen (not bad?)
With Sto-fen (better?)
Brett
http://www.pbase.com/shreder
The Journey is the Thing
Brett
