Tom Batinich
I think some are missing your point.
Thx for your continuing interest. I have to agree, it does look like vignetting is the culprit.I downloaded those sample JPEGs and examined the median luminosity
values for a 9% circle in the center. Here are the results:
35mm f/2: 125 (20.5%)
35mm f/5.6: 139 (25.8%)
135mm f/2: 126 (20.9%)
135mm f/5.6: 131 (22.7%)
The big difference is obviously on the 35mm lens. The difference is
a factor of 1.26, or just barely under 1/3 stop. 1/3 stop is the
minimum metering and exposure increment on the 5D.
My conclusion, then, is that it does seem to be entirely the
vignetting. The camera is metering for the center of the image
(center-point AF with evaluative metering) and is getting
consistent light readings. The subsequent exposure is giving
consistent results in the centers of the images. The images appear
lighter or darker depending on the amount of vignetting present.
It's in the EXIF of each sample.Where do you see -1 EC .... shouldn't be any.... unless I goofed.Why is -1 EC set for each of the samples?
You're always going to have cos^4 light fall-off at the least. With a digital sensor, this tends to be further exaggerated by the microlenses which are less sensitive to light coming in at an angle.What lens is long enough that there should be zero vignetting?
Are we looking at the same exif? Neither opanda or DPP show any EV comp that I can see....It's in the EXIF of each sample.Where do you see -1 EC .... shouldn't be any.... unless I goofed.Why is -1 EC set for each of the samples?
First pic:
Exposure Time: 1/125 sec
F Number: 2.0
Exposure Program: Aperture Priority
Exposure Bias Value: -1
Yea, it's kinda frustrating when folks diss you without seeming to understand what you're talking about..... hey, but such is lifeI think some are missing your point.
Thx. Got my 5d for xmas .... only 1200 clicks in ... but I'm pretty good at disecting a cam's performance (if I say so myselfTry centerweighted averaging metering and see what that gives you.
Evaluative on Canon SLRs is basically linked partial metering -
linked to the active AF point when metering was locked.
I am constantly moving my EC from -2/3 to 0 most of the time.
Sometimes -1 and + 1/3.
Are we looking at the same exif? Neither opanda or DPP show any EVIt's in the EXIF of each sample.Where do you see -1 EC .... shouldn't be any.... unless I goofed.Why is -1 EC set for each of the samples?
First pic:
F Number: 2.0
Thx Jonas,According to SLRGear.com the EF135/2.0L vignettes up to a 1/4 of a
stop when tested with a cropped sensor. It doesn't seem
unreasonable that this number increases quite some with a FF sensor.
Hi Tim, in our kitchen here.... did your wife pick out your wallpaper too?I have done many lens tests on that bathroom wall paper. None of
my tests show this under exposure with shots taken with my 5D but
my 10D under exposes about half a stop. Sorry I could not be much
help.
Tim
Why i didn't look to dslgear.com to begin with, I dunno ....
Great tests IMO.
Here's the link to their site .... the 135mm's vignetting on FF.
I'll say it again ... never expected vignetting to be an issue at
this focal length.
best, mark
He was using center-point AF, so the evaluative metering took the center as his subject.you would think especially with evaluative metering, that if
vignetting is less light being read by the sensor, that the
exposure value would adjust to some extent, no?
