koolzakukumba
Well-known member
Great link, Mark. Thanks.
Bruce
Bruce
i used to buy the cheapo kodak gold for $1.28 just few years ago, and now its $2.50. seems like you were hibernating for a long time & missed Kodak's announcement. http://gizmodo.com/gadgets/digital-cameras/kodak-to-charge-more-for-film-167755.phpFuji Reala is 2.49 a roll. I can buy B&W MF film for $1.39 or buy1) film price is rising, due to decreasing production.
35mm in 100 foot rolls for dirt cheap.
again, most of the renowned analysers say, a 11/16 mp HQ 35mm sensor is sufficient to make output as good as or better than MF6x7 negs. So, put the price of an Imacon 343 in the equation, and voila! the cost is same! and the added bonus is, "less hassle", and a RAW file to work with, instead of gamma curve applied tiff/jpeg.How much is that 22mp back
that is almost as good as my MF 6x7 B&W negs?
what about changing the white balance in the raw file, or bringing out shadow details by giving a 0.5 EV push, before applying the gamma curve? and there is something called 32bit HDR, implies for both film and digital as a solution for demanding DR situations.Odd, my scans of Ilford FP4 and HP5 are 16bit, and offer better2) you wont get the flexibility of RAW file, from the digitized files.
dynamic range than ANY DSLR on the market.
When I scanned (post tense) B&W film on a drum scanner I preferred to shoot in 6x7 format because that way I didn't have to scan higher than 2000dpi. The quality of 35mm B&W film degrades horribly beyond 2000dpi, unless you're using TechPan or TMX 100.For fine-grain films (Pan F) scanning at 4800 doi does the trick. For coarser films (such as TriX) scanning at 3200 does it for me.
Guess you don't know how to use a dSLR then if you're getting more D-range with FP4. I wrote both the process workflow and scan tables for FP4 for a couple professional labs, and this material does not have more dynamic range than a typical dSLR.Odd, my scans of Ilford FP4 and HP5 are 16bit, and offer better dynamic range than ANY DSLR on the market.
--In my testing with the same scanner, a 35mm scanned Astia chrome
still outresolves my 10mp 400D....albeit with grain. I'd say that
most people would find 10mp a good match for 35mm fine grain film.
ScottWhy can't you just admit you can't use a dSLR like an adult?
You may think so Scott, but your ego doesn't matter here. The scans I get from my Imacon from Pan F developed in Pyro will will slaughter your desaturated Provia, etc. In fact, the resolving power of the B&W film will be far, far greater than the color film....not to mention the fact the spectral response of the color film will look very different to the B&W film.When I scanned (post tense) B&W film on a drum scanner I preferredFor fine-grain films (Pan F) scanning at 4800 doi does the trick. For coarser films (such as TriX) scanning at 3200 does it for me.
So, when we put this equation together, you're claiming your 35mm
B&W has more resolution than my 6x7 B&W.
Personally if I were forced to use conventional film and required a
monochrome product I'd shoot 6x7 chromes and desaturate, and blow
you B&W reel flippers into the dirt. We know you aren't capable of
producing a color product without a lab tech thinking for you
anyways, so you elevate the quality of conventional B&W process far
beyond what anybody cares about.
I don't own a mini lab...I own a scanner and film gear. The RB67 I bought 5 years ago may have depreciated by $100. How much has that 10D or 1Ds depreciated the SECOND you walked out the store's door? Ya, thought so. The depreciation on the digital gear pays for my MF and sheet film every year.As for depreciation, which is a stupid arguement in general, I've
wondered if you've checked the depreciation write off of mini-labs
using hundreds of thousands of dollars of film based production
equipment. My Canon 10D cost $1400 when I first got it, and it
still continues to blow away 99.999% of the 35mm work I see posted
in this forum. 100% of Les's work, which as I've seen on Photo.net
could be bettered with a 5yr old using a disposable film camera.
No argument from me about MF beating 35mm. I feel sorry for you if you think your 10D beats out scanned Pan F in 35mm format.One of the laws of photography I've learned is that film users use
absurd dpi arguements as a crutch to get around their lack of
skill. I know the quality limits of Provia and Velvia when drum
scanned because that's what I used to do for a living. I even have
a functional MF camera that when loaded with film uttery destroys
35mm formart regardless of scan resolution. Yet I continue to use
an outdated 6mp dSLR because film sucks and I don't need an
emulsion engineer at Fuji or Kodak telling me how to think. Nor do
I waste time shooting resolution tests to make up for my lack of
camera skills. I feel sorry for those of you that do.
I didn't miss any announcement. Arista B&W film is $1.39 a roll for MF. I looks like you just don't know what you're talking about.i used to buy the cheapo kodak gold for $1.28 just few years ago,Fuji Reala is 2.49 a roll. I can buy B&W MF film for $1.39 or buy1) film price is rising, due to decreasing production.
The 1Ds Mk2 prints I have say different. B&W work I've done with both the Mk2 & B&W film show the B&W film to easily beat out the Mk2 at 20x30 print sizes. Price of the Imacon was $3500. Price of the Mk2 is $8000. So much for your "Voila" comment.again, most of the renowned analysers say, a 11/16 mp HQ 35mmHow much is that 22mp back
tiff/jpeg.
Yes, but I can get 13 to 14 stops of information with TriX....NO DSLR even gets close. There is just no tonal data even at the 10th stop with a 12bit sensor.what about changing the white balance in the raw file, or bringingOdd, my scans of Ilford FP4 and HP5 are 16bit, and offer better2) you wont get the flexibility of RAW file, from the digitized files.
Whether or not something is easier has NOTHING to do with quality....only quality does!Listen, I was a long time film user too. But with digital, life is
a lot more easier and i find the chain of workflow to be a lot more
consistent. And, I no longer need to worry about keeping exposed
Provia under 25*C, where i'm shooting in 40*C.
Scott, it is well know than you can get between 13 and 14 stops of data from FP4 using dilute developer solutions and stand development. A DSLR with a 12bit sensor has no tonal data at even the 10th stop. The problem is your Kwiki Mart labs don't know how to process B&W film. People like Bruce Barnbaum are well versed with dragging dynamic range out of B&W film. I learned from his process. Before you spout off like you normally do, I suggest you do some reading on this issue.....because if you think a DSLR can beat out B&W film like Tri-X and FP4, then you been misinformed....greatly.Guess you don't know how to use a dSLR then if you're getting moreOdd, my scans of Ilford FP4 and HP5 are 16bit, and offer better dynamic range than ANY DSLR on the market.
If you're also preaching that scanned film has a faster workflow
than digital capture you might want to get a job as a Carnival
barker because we'd take you more seriously.
He's always like that Mark. Even on Photo.net where many, many people in the thread would point out his error, he would just become abusive and vacate the thread.ScottWhy can't you just admit you can't use a dSLR like an adult?
You are a great photographer, no inadequacies there, but as a
person you have the finesse of a street brawler and the rudeness of
an ignorant, petulant child.
I often read your posts (I hope some of your points are tongue in
cheek) and are amazed by the ignorance and overall lack of
knowledge, especially in the field of photo-processing where you
seemed to stop learning circa 1987.
Why for once can't you behave like an adult and put your points
down without going down to the lowest common denominator?
Mark
http://www.photo-utopia.blogspot.com/
Nope, I'm talking about a $3500 used scanner and Astia that blows away a $700 DSLR....in fact, still blows away the 5D as well....in fact, holds it's own to an $8000 1Ds Mk2. Anything else?the OP was bringing up the issue due to economic reasons. and you
are talking about a $5000 scanner and Astia chrome to get the
quality attainable with a $700 10mp dslr?
ROFL...
Regards, Aador.
http://www.thelightcollector.com
you never know, to whom which is more important! Try to get mature, being financially solvent, you haven't got a license to deny the fact that, no one should have financial constraints, and should look for quality, regardless of the cost. ..still a child...! Grow Up!It's funny how when film is mentioned, the primary concern people
have is the cost rather than the quality.
I have spentI guess spending multi
thousands on a new DSLR every few years is ignored by them.
exactly, what makes you think that you are the only one who does that? silly!Maybe
if they concentrated on capturing an image rather than
mind your own business... rather than looking for, what people do with their cameras...!jackhammering a shutter 50,000 times a year to get pictures of
their cats, they could afford the better quality of film.
--I didn't miss any announcement. Arista B&W film is $1.39 a rolli used to buy the cheapo kodak gold for $1.28 just few years ago,Fuji Reala is 2.49 a roll. I can buy B&W MF film for $1.39 or buy1) film price is rising, due to decreasing production.
The 1Ds Mk2 prints I have say different. B&W work I've done withagain, most of the renowned analysers say, a 11/16 mp HQ 35mmHow much is that 22mp back
tiff/jpeg.
Yes, but I can get 13 to 14 stops of information with TriX....NOwhat about changing the white balance in the raw file, or bringingOdd, my scans of Ilford FP4 and HP5 are 16bit, and offer better2) you wont get the flexibility of RAW file, from the digitized files.
Whether or not something is easier has NOTHING to do withListen, I was a long time film user too. But with digital, life is
--Nope, I'm talking about a $3500 used scanner and Astia that blows
I would rather argue with someone who knows what they are talking about.i would rather argue with you when you'll be out of the hangover....
tiff/jpeg.
Regards, Aador.
