Dean:
Using RAW with your 30D, can you shoot more than eleven (11) using
5 fps?
I guess my question is; does the higher speed CF (yours is 150X)
allow more than eleven shots at the 5 fps rate? Or is it governed
by the camera's buffer?
Glenn NK
Victoria, BC
So much to buy - not enough time and money - too much GAS.
That's going to be governed by the camera's buffer speed. If you notice on the tests, they always stop at the camera's buffer limit. Because in reality, if you read the speed in which it rights, it corresponds to a certain number of pics per second. In order for the camera to continue writing to the card, it would have to dump at least 5 images off the buffer in order to increase your shots per second. Typically, you could see 1 or 2 extra shots, but usually those are not in the same rapid fire sequence.
Simply put, these card speeds do not have the power to keep up with the camera. For instance (I know this is crossing numbers, but it's still relevant) if you take a picture that's 5.2MB (a file from my 10D) and you use my card which has a 5.999 MS/sec speed (this is the crossover number because i'm using the speed of a 30D with the file size of a 10D). That means that it can write 1 file per second. So while on my 10D I can shoot 3 fps, when it gets to the buffer limit, it drops to 1 fps. Now, if the file size jumps, then of course my fps will drop even more.
So yes, the number of pictures you can take is limited by the camera buffer, but the difference between clearing those images off is with the card. If you have a slow card, you're going to wait longer before you can start shooting again. A 3 MB/sec card will take 2 seconds per 6 MB file, so if you fill the buffer with 11 shots, you'll be waiting 22 seconds before you can use your full burst mode again.
But to make a quick mention here, when you read the specs from flash card makers, they list it as mb not MB. Yes, sounds stupid, but it makes a huge difference. They are in fact different file sizes.
Small b is one 1 or 0 while big B is a group of 1 and 0's. So 1 MB is more than 1 mb. Just thought you might find that helpful when looking at the card speeds. Otherwise, stick to Rob G's site, pretty good.
