Wow man... like at f3.5 @ 200mm @ 3m subject distance, the DOF is 2.2cm!
Is that right?
Here's the page:
http://www.olympus-esystem.com/dea/products/lens/50-200_28-35/index.html
Even if you stop it down to f11, DOF is still only 7.1cm!
200mm @ 5m @ 3.5 is 6.7cm, closed up to f11 is 21cm!
Is that right?
I have another quick query: using the teleconvertor with the 50-200. It gives you a combined aperture (fully open) of f4-4.9.
Is the DOF still the old 2.8-3.5 or is it now f4-4.9? I thought the teleconvertor just dimmed the light, not added DOF optical properties?
Thanks..
I guess I'm just a bit shocked at the DOF seeming so small. I thought I had more range than that?
Is that right?
Here's the page:
Is that right?
Thanks..
