Shootout: Tamron 17-50 2.8 vs Kit lens
The Sigma hunded focus more. It rocked back and forth like it
couldn't make up its mind. But atleast one of the two positions
that the Sigma couldn't decide between yeilded a sharp picture. The
Tamron locks target, and then does not move that much when the
button is half-pressed again. I'm not sure though that that is to
the better, because as I have found, even though the Tamron has
locked focus, the results can come up blurry due to misfocus.
(I'm mostly talking f/2.8 here, and perhaps my copy had a slight
front focus issue)
Flare resistance is not a concern of mine, so I never tested that,
and now I have returned the lense.
Why did you return the lens? Were you testing it? Or did you buy it and decide that you didn't want it?
If this isn't the case, then which one do you prefer? The Sigma or the Tamron?
I've got a Tamron 28-75 that I like, other than the fact that 28mm isn't wide enough. I'd like to replace it with the new 17-50, but only if its performence is comparable. My copy of the 28-75 is somewhat soft at f/2.8, but is really great at f/4 and above. So I'm not demanding perfection at f/2.8. But I don't want to see any erractic focusing that produces images that are grossly OoF at f/8.0, because my 28-75 isn't erractic. So long as I avoid f/2.8.
Wayne
The Sigma hunted focus more. It rocked back and forth like it
front focus issue)
Yes, I bought it and decided it was not for me. For now atleast.
the Tamron?
It's a tough question.
The sigma has a warmer color cast than the Tamron which is more neutral, so a + for the Tamron there. (a matter of taste, and correctable when shooting RAW)
The Sigma seemed to me to be sharper at f2.8, especially at 50mm, but I guess later reviews can settle that. The center sharpness seemed to be better with the sigma, BUT the Tamron has considerably better edge and corner sharpness.
AF issues I've allready mentioned previously. The tamron is a bit noisier.(or perhaps it's only that the sound is more high-pitched)
I guess It comes down to what one intends to use the lense for. For me, center sharpness, and decent sharpness at 2.8 is important, especially at 50mm for portraits - and I guess many would say: "well, then get a prime", but I've used the Sigma,and become used to a handy zoom. I guess I expected more from the Tamron.
Also, with the Tamron, while making the test (using 350d, MLU, 2 sec timer, Av-mode) I got "error 99" at least 6 times, forcing me to remove and replace the battery. Never happened before.
weird.
Also, barrel distortion seemed to be worse on the Tamron - shooting pics of artwork even at 38mm resulted in (slightly) bent frames near the edges.
well, maybe It wasn't a tough question after all - I'd say I preferred the Sigma.
Wayne
Remember, I might have gotten a not so good copy. The overall sharpness when stepped down a bit is excellent, really good at f4, and it shines at f5.6. I presume it is comparable with the 28-75 which I have heard a lot of good things about. I am actually considering getting that one instead.
The only thing is I've read that AF at 28mm 2.8 is very poor, throwing the focus off totally in some cases. What's your experience?
I dont think I'd miss the wide end that much.
pusseapa
Pusseapa wrote:
Thsnks for answering my other questions.
Some people have reported that it is sharp at f/2.8--all you need to do is either keep trying different copies, or send it in for calibration until they get it right. But three months of doing that exhausted me. I don't know what percentage are razor sharp at f/2.8 and what percentage are soft at f/2.8, but improve real quick. (Like mine is.)
I am actually
experience?
I don't use it at 28 much. Truth be told, I'm not sure that I want to give it up after all. I seem to use the 40-75 range most of the time. For candid people shots. The times I need to go wider than 28mm is when I'm shooting landscapes and can't back up enough to fit everything in 28m. I don't think I could live with 17-50mm only.
Depends on whether you do landscapes. Or "street" photography. Or interiors.
After reminding myself that I really need a lens that goes longer than 50mm, right now I'm thinking of trying the Sigma 17-70mm and keeping my 28-75. Dunno. We all want a 18-500 f/2.8 IS lens that is razor sharp at all apertures and focal lengths. And costs $199 and weighs less than a pound. Barring that, we need to make compromises. We can't have it all. (But is is helps to eliminate the duds.)
Wayne
What's going on?
