homunculus
Member
What would be different about the light provided by the two? They both basically disperse and soften the light correct? Or maybe I am way off...
Thanks in advance,
Evan
Thanks in advance,
Evan
Whilst this may be true, it doesn't make much difference in the light that falls on the subject. There is no reason to have an even light distribution across the face of the modifier unless.....A good light box has a uniform brightness on the front panel. An
umbrella generally has hot spots and fall off.
Which also means you have to like square/rectangular catchlights in people's eyes (in the case of light boxes). Seems to be currently "in fashion"...didn't used to be. Photographers used to go to some expense buying stuff like Broncolor Opal-light (think that was the product) reflectors to get round catchlights. The Westcott Halo will give you octagonal catchlights.Whilst this may be true, it doesn't make much difference in theA good light box has a uniform brightness on the front panel. An
1) the modifier appears reflected in the subject, say the eyes in a
portrait
and....
2) UN-eveness in that refection is something you personally don't
care for.
Myself, I don't think it's any big deal, one way or the other.
What softboxes do is contain the light, and direct it exclusively
forwards.
Umbrellas tend to spill more light around the room, which can be
helpful, by providing light from additional directions, but
sometimes is not, because the quantity of bounced light is not easy
to control.
Either way................
The difference in how the subject appears is very small indeed, and
the choice of brolly or softbox has nothing to do with how even the
light might be across your subject.
Even-ness, or lack of it, is a matter of how you use your lights
and their modifiers, not which ones you use.![]()
Baz
You can have a softbox and pleasing looking circular catchlight by simply adding a circle mask to the front of the softbox. Photoflex supplies circle masks with their MultiDome Q39 series. Strip masks, louvers and egg-crate grids are also available.Which also means you have to like square/rectangular catchlights in
Who said there was a "right" shape?I don't think there is a "right" shape for a catchlight.
All well and good if you are trying to simulate the look of someone standing near a window. If you aren't then the window-like reflection may appear to be out of context with the setting.A rectangular window will produce a somewhat rectangular catchlight
(bent somewhat by the shape of the eye). If the window is very
close, the catchlight might not even seem to be there, but at a
decent distance, the rectangular shape is perfectly visible.
There are no rules or absolutes like "right" or "wrong". The poster I responded to implied that if a rectangular SB was used one was forced to accept rectangular catchlights. I pointed out that if the look of round catchlights is preferred they can be achieved with a softbox by using a circle mask. The explaination of how to do it was not intended to imply round was right or better.Is having a circular catchlight any more "right" than that?
Well if memory serves its also obvious she is sitting near a window in that painting. If she were depicted in the middle of a field outdoors or in the middle of an artificially illuminated room at night the square catchlights would be out of context, no?You can go all the way back to Vermeer and other painters who used
the camera obscura in their work and see rectangular catchlights in
some portraits. In Vermeer's "Girl with a Pearl Earring," you can
see the squarish window shape quite clearly in her eyes (although
Vermeer went for a soft focus look in that painting, likely because
his camera obscura's lens wasn't so sharp).
I agree that the catchlights, regardless of size, shape or number shouldn't be a noticable distraction, unless done intentionally. Granted those might be out of place for a conventional portrait, but aren't such artificial catchlight reflections "normal" in the life of a fashion model and therefore appropriate to the context of a fashion shoot?The only shapes which bother me as catchlights are those which are
obviously the result of umbrellas, ringlights or other lighting
devices you would not see in normal life.
Uh, window lighting is one of the best and easiest ways to get catchlights in the eyes. It can also produce some beautiful lighting. All of the following are with only window lighting. No nuclear blast next door either...I've never seen a window produce a catchlight in someone's
eyes...maybe if there was a nuclear blast next door...
I didn't know that...I'll have to check out Photoflex Multidomes. Maybe I can trim down my stuff a little.You can have a softbox and pleasing looking circular catchlight byWhich also means you have to like square/rectangular catchlights in
CG
