Agramer
Leading Member
Not exactly clear enought but I can accept that I'm wrong. I'm biology high school teacher and I'll trust you on your wordPerhaps because the sharpness of lenses and sensors declineHm, OK. . .but why we can see lens limitation on the 8mix sensor if the lens is capable for 16 mpix?
gradually as line pairs get smaller. There is not a sudden cut of
with perfectly sharp images at, say, 59lp/mm and no detail at all
at 61lp/mm.
Whenever lens and sensor/film are reasonable close in resolution,
the combined sharpness will be noticeably less than either is
capable of alone. For example, if a lens and sensor both have 50%
MTF at 60lp/mm, the combination will have 25% MTF at the same
60lp/mm (MTF factors multiply: 50% of 50% = 25%.) So the image is
"one stop" softer than either the lens or sensor is capable of on
its own, if either the lens were used with a "perfect" sensor, or
the sensor with a "perfect" lens.
Moving away from perfection, the natural combination in digital
will probably be going to sensor MTF higher than lens MTF, so that
the combined MTF is close to the limits of the lens alone. I guess
that because it will probably be easier and cheaper to keep
improving sensor resolution.
Olympus using term Pro lens for 11-22; 14-54; 50-200 and 50macro. For 7-14; 35-100, 90-250; 150 and 300 they use term High grade pro or something similar.P.S. You originally talked about reoslutio limits of the "pro lenses":
So why are you now using the example of the 14-54/2.8-3.5, which isOlys pro lenses are capable for 8-10mpixels on 4/3 sensor.
a mid-priced, "advanced amateur" 4x zoom? "Pro lenses" to me
suggests ones like the 11-22/2.8-3.5, 7-14/4, 35-100/2, 90-250/2.8,
50/2 macro, 150/2 and 300/2.8.
Thanks for the R. . .and sorry on bad english
Cheers
