What does fps mean?
newtothisgame
Member
Markham, CA
As my identity suggests I am new to this and I have just purchased the D50 with the 2 lense kit.
One of the specs for the D50 is 2.5 fps. What does this mean? My first thought is that it allows me to hold down the button and it takes 2.5 shots per second. I know I am totally wrong. I am hoping someone can explain.
Then this leads me to my next question.
How can I take those rapid shots?
Jeff
Hold the button that has something like 3 squares and move the dial command, and you can see at the top LCD that it changes from S to the same (3 squares)
newtothisgame wrote:
explain.
Jeff
Best Regards,
Arne
Your camera is able to shot 2.5 frames (pictures) per second. The camera must be set to continues shooting mode and probably in the AF-C mode (it's in the manual...). Point the camera on the subject, press the shutter release half down to allow camera to focus and then press it all the way and hold it. You'll get 2.5 pictures per second as long there is some free space in the buffer.
Regards, Bostjan
http://www.pbase.com/bostjan
Regards, Bostjan
I can't seem to get it to work with the flash on. Can this not work with a flash?
Jeff
Depends on the power of the flash, but its nearly imposible for the flash to recicle (charge) 2.5 times per second, usually the onboard flash at full power will take arround 2 to 3 seconds to recicle.
Z.
I do not suffer insanity...I enjoy It
Z.
So what woudl be the best settings to do this burst thing? When I set to manual and have no flash the picture is black.
Jeff
For the speed burst to work you have to have a lot of light, so a fast lens is really good in this situations. Usually you will use this while outdoors, in the sun, so light will not be a problem.
If you really need to use your flash, get an external flash and a external power souce, this is not the cheapest rig you can get, but it will work.
If you dont mind me asking, just what are you photographing?
Z.
Well I was trying the idea of water falling, so trying to catch droplets of water falling into a pool of water. I have seen this done here and I just purchased my D50 and was tyring to recreate this photo.
You need to learn a little bit about exposure more if you are in manual mode, your pictures are black, and you do not know why. Your shutterspeed is either way to fast, your aperture stopped down too much, or both.
Try using Aperture priority on a high f-stop (f22) if you want the waterfall effect with blurred water. If you want to FREEZE the action of the water, you need a higher shutterspeed, lower f-stop (f2.8, f4, etc) .
Id recommend buying the book 'Understanding Exposure" by Bryan Peterson.
Z.
Jeff
'87.6% of all statistics are made up on the spot'
ShutterBugin
http://www.exposureproductions.smugmug.com
FPS is indeed frames per second.
I shot a sequence of pictures of a crash at the Eurocircuit, Valkenswaard, Holland this weekend during a rallycross race.
Pictures aren't any good but you can see what continious shooting is.
Taken with a D70s that has 3 fps pictures just cropped to 33% no pp.
http://mijeenrotz.org/1/crash.html
Photographing waterdroplets is a whole other game. To freeze them one uses a very fast flash in a dark room with the camera in bulb mode. The flash is triggered by the droplet breaking a detection beam.
More info about that here http://www.hiviz.com/index.html
It can be done by shooting with the onboard flash, the camera on a tripod and counting the drops. I've done it that way.. But that is hard and you'll get a lot of bad pictures.
Whoa! Just had a flash back. FPS use to mean "Focal Plane Shutter" for flash sync. I'm too old for this game. I need a drink.
Dave
