Hi lllZ3R0lll (wow!), I had the same hard time deciding.
During three weeks (about a month ago) I gathered 27 items of information (like image size, zoom range, price, etc) about 41 camera models, and arranged them in a work-sheet-like document to help me choose the camera that would best suit my needs.
The data came from
http://www.dpreview.com and
http://www.imaging-resource.com
Like you (but for a different reason) I left out all the dSLRs, so that my list was made up of "prosumer" cameras only (although ALL advanced models were on the list).
After many hours of navigation inside my list, I discoverd somethng I was unaware of before I started the research:
I should give up trying to select THE best camera, and should instead, pick TWO cameras to fill my needs.
The reasons soon became obvious:
1- No one camera had everything I wanted.
2- With two cameras, I can zoom all the way from 24mm (19mm with WA converter) to 432mm (734mm with 1.7x tele converter).
3- With two cameras, one of them can have all the pro features (manual mode, dedicated flash, bracketing, etc) while the other can be simpler (which means less expensive).
With that in mind, the difficult job became very easy.
I decided to buy the Sony DSC-R1 AND the Panasonic TZ1.
You are aware of the qualities of the R1, but you also know that it does not have Image Stabilization, it has a poor zoom range, and it does not do movies.
Ok, I don´t mind. The TZ1 has all that, and wiith the new "Folded Optics" design, it is small enough to fit in a shirt pocket. On top of that, its movie is 16:9 wide screen format, larger than VGA!
The decison was made. I received the R1 eight days ago, and I will get the TZ1 on my next trip to America, in June.
I hope my strategy makes you a little happier.
By the way, the reasons I left out the dSLRs are:
1- I want to have LIVE LCDs.
2- I don´t want to commit myself to a brand.
(If I were to buy a dSLR with three or four lenses, two or three years from now, I would be looking for upgrades only from the same manufacturer, in order to re-use those lenses)
3- The two cameras I selected cost less than one of the three or four SLR lenses needed to cover the same zoom range.
JJDiniz, from Brazil
