Well, you still did not address the issue of dropping, which is always a potential problem, and worse as you get older. Not only might the lens be damaged, but it could also be lost overboard or over a cliff. Also, I forgot the issue of moisture due to rain, other water conditions, or condensation.
I use zooms most of the time, and I carry multiple bodies (at least 2) so I can minimize lens changes and have instant full coverage. When I am in a situation where I am not sure what the targets might be (anywhere from large scenic to closeups of faces) and where they can change rapidly I might be using 3 bodies with 3 zoom lenses covering from 12mm to 400mm. But on those occasions when I need the capability of one of my primes I will use it (assuming I have it with me).
Fast primes provide for very low light conditions and very shallow DOF, both of which can be important, albeit in a limited number of circumstances. I would hope the "primes all the time" purist would also focus and meter manually as well since MF and MM offer the optimum control for both.
Anyhow, in line with the season, I wish good shooting to all, and to all a good shoot.
