I'm not sure if you're understanding the others.
Every time the F707 fires its flash (I'm not talking about the
multiple strobing of red-eye reduction mode), there are most
definitely TWO flashes: The first is a pre-flash which fires a
burst of light after which the camera calculates the necessary
flash power needed for decent exposure; then a fraction of a second
later, the camera fires a second flash at the power that it has
deemed necessary. This may be too fast for your friends to take
note of, but it definitely should be operating this way.
When Sony tells you that the other flashes are not compatible, they
most likely mean that you cannot electronically connect those
flashes to your F707. The only officially recognized flash for use
with this camera is the HVL-F1000, which "talks" to the camera via
the ACC port on the right rear upper side of the lens barrel. This
flash also has its own sensor. It's a so-so flash as external
flashes go. But it can get the job done. I like it.
To work around your problem when using slaves, you need a slave
that is configurable for working along with cameras that fire a
pre-flash. For example, try this place:
http://www.srelectronics.com
They have some very interesting products you may be interested in
if the HVL-F1000 is not what you're needing.
However I've made sure that the red eye reduction feature was
turned off.
People watching the flash strobes also stated that there was no
2nd flash from the 707 camera body. The 2nd flash was being
emitted from the slaves.
Any other ideas?
David
As recommended many times on this forum, I would add my
recommendation for
http://www.srelectronics.com who sell a range of
slave flash modified to work with digital cameras, basically a
switch has added to tell the slave to fire on either the 1st or 2nd
burst of flash it detects.
These flash units from sr are quite expensive, but the customer
service is excellent.
.Ray
Does anyone know of flash sync issue between Cybershot 707 and
remote slave flash (using flash as sync)?
I shot a party last night using -2- slave flashes.
Could not get the slave flash consistently sync with this camera.
Although the slave flash was triggered by 707's on board small
flash, there seems to be a timing lag.
My oberservation is that the 707 delta time between the flash and
the CCD recording is shorter than my SLR (is this correct)? Thus
the effects of the slave flash was nominally useful.
Perhaps this is an issue with digital camera overall?
Anyone with useful insight, please respond.
Much thanks!
David H
