200 f2.8 + 2x vs 300 f4 IS +1.4x
JustinF
Member
St Louis, MO, US
I’m looking to get a long prime to supplement my 70-300 DO. I find that I use the long end most often and want to get to 400mm relatively cheaply while still being as versatile as possible. I had the 70-200 L IS and found it a little to heavy to carry often so I sold it for the DO. I have the Tamron 1.4x TC (MC-4 cheapy) and it is pretty slow on the DO. I am thinking about getting:
200 f2.8 L + Canon or Kenko (300 Pro) 2x TC
659.95 + (259.95 or 214.95) – 25 rebate = ($849.90 - 924.90)
or
300 f4 L IS
1149.95 – 45 rebate = $1104.95
That’s only a $180 difference. The price is even closer because I would need to buy a 72mm CP for the 200 and I already own a 77mm CP for the 300.
I have seen some surprisingly good reviews of the 200 with 2x TCs, some surprisingly poor reviews of the 300 with 1.4x TCs, and no reviews comparing them. The 300 is a pound lighter than the 70-200 IS I sold, and is reportedly less front heavy, so I don’t expect that to be as big of a problem. The 200 is smaller, lighter, black, and gives me three usable focal lengths. The 300 is a bit less versatile but has IS (a good thing at 420mm). I would consider the 400 5.6 but I would like to overlap my 70-300 DO for lower light conditions and when I want a really sharp image.
Which is sharper the 200 L f2.8 + a really good 2x TC or the 300 L IS f4 + a 1.4x TC? Assuming the price difference was not as big a deal as the quality — which would be a better setup for overall versatility and usability?
If you like to shoot at 400 buy the the 400/5,6 lens.
And the 300/4 + 1,4 is sharper and better than the 200/2,8 + 2X tc
That's what I think too. I am not that happy about the sharpness from the 200 plus 2x (compared with just the 200).
Misha
Thanks for your recommendations. I have seen so many reviews of how bad the 300 f4 (IS model) is with a 1.4x TC that I thought maybe the 200 would give similar results and give me more lens options. There are a bunch of posts right now about how good the 200 L is with a 2x TC. I can’t justify the 400 L because it limits me to using only my DO from 70-300. The DO serves it purpose (I think it’s great lens) but could be faster and a bit sharper. I just want to have a better option in that range and a bit more reach.
Wow — from the first test the 200 f2.8 + 1.4x looks sharper than the 300 f4 IS naked. The second test seems to show that the 200 f2.8 + 1.4x is sharper than the 135 f2 + 2x and that the 200 f2.8 + 2x is only slightly less sharp than the Bigma (50-500mm) at that distance. All of this is very surprising to me and makes the 200 look pretty good. It is only one test however. Thanks for the examples.
I'd say in these samples the 200+1.4x acquits itself well, but 200+2x does not look good.
Misha
I would be more inclined to say the 200+1.4 is about equal to the 300/4 and the 135/2+1.4 is about equal (perhaps a little better) to the 200/2.8 bare.
Considering the 300/4 is longer and has IS, I'd go for the 300 easily over the 200/2.8 + 1.4. Likewise for the 300+1.4 over the 200+2x. It's pretty hard to handhold in all but the best conditions at 420mm.
Lee Jay
(see profile for equipment)
So many tests have shown the 300IS loses a lot
of its sharpness with a TC including this newer one
from Photozone
http://www.photozone.de/8Reviews/lenses/canon_300_4is/index.htm
but the 300 non-IS is remarkably sharp with the 1.4x TC.
Photozone also did a recent test of that lens
http://www.photozone.de/8Reviews/lenses/canon_300_4/index.htm
The 300 non-IS with a 1.4x TC is much sharper than the 300IS with
1.4x TC according to these tests and many others. The 300 non-IS
with 1.4x TC is nearly as sharp as the 400/5.6 on a 1.6 crop (Rebel XT)
according to Photozone...and that's pretty sharp!
http://www.photozone.de/8Reviews/lenses/canon_400_56/index.htm
The 300 non-IS can be found used for between $600 (seen one at this
price once) and $900. No IS but if you use a monopod, tripod or keep
your shutter speed to 1/f, you get a very sharp lens for less.
I have the kenko Pro DG 2x and the only thing that I find difficult is birds in flight with the combo, but I think it's poor technique rather than limitations of the lens and TC, though the AF is noticeably slower (but accurate).
I have toyed with the idea of selling them and getting the 300 f/4 or 400 f5.6 as I have the Canon 1.4x too, but I can handhold the 200 very easily and I don't know if I could do the same with the other primes. The other thing is I have stacked the 1.4x and 2x on the lens and gotten usable shots, and the combo still auto focuses on my 20D. I can even use AI Servo.
I probably wouldn't trade in mine until I'd rented a 300 or 400mm to make sure it would be something I could use easily -- maybe renting is an option for you before deciding?
Cheryl
