Fuji S9500 problem ?
h holland
Member
dollard, NL
hi there,
I made the following pictures with an Fuji S9500 and there is a strange spot in it. It's a night photo with strong backlight.
I included two pictures. The second shows the flary spot.
Is there anyone who has an explanation for this spot ?
Besides this I can say that I'm quite happy with this camera.
Greetings
Henk (from Holland)
hi there,
"flary" is a good hint, since it looks like a lens flare caused by the complex lights on the left side. It also has the typical appearance of several optical reflections/refractions of light like a blue edge on one side and a greenish/yellowish edge on the opposite site (S9500 lenses are not prims, but still reflect and refract light beams).
Looks to me like the Truth is out there!
S
Pssst or I'll tell you, how UFOs appear on photos shot through a closed window ;)
Ohhh, you gone and spoilt my fun now.
What about this shot then with a closer up view below? Sydney Harbour Bridge. Object above the bridge not seen till downloaded image. Tripod mounted, ISO 64, F1.8, 3.2 secs exp, taken on my trusty old Olympus C5050. Note the shape and texture of the object, so it ain't no flare from lights. Note also how the clarity of the object alters as it goes behind cloud. This is no BS image. I still don't know what the object is.
http://www.flickr.com/photo_zoom.gne?id=64288652&size=o
http://www.flickr.com/photo_zoom.gne?id=64288653&size=o
Snaps
Snaps
Why do the lens fl.. eh.. appearings of some unknown object have these gaps between them? If something moves, it should at least have a steady trail or so.
BTW, if you want to impress someone, show them a bright Iridium Flare!
You can look up on the net, when you can see them (www.heavens-above.com).
Sorry Dres, I don't understand your point. What does "fl.. eh.." mean? This is a genuine photo that I took with an Olympus C5050. This is not a prank. As yet, no one can explain it. Tripod mounted, no camera movement. Yes if it was a moving object, it should have a steady trail, so I assume it's some other optical causation. But what? How? Why does its shape change and why is it ringed?
Any ideas of where I could send it to to get a bigger (numerically) response?
Cheers
Snaps
it ringed?
I just didn't want to spoil your fun :) Don't you know "lens flares" ? In an optical system like that of a camera you have sometimes 10 or more single lenses. All of them reflect some light, have differently curved surfaces etc. If you point the camera to some really bright lights while the rest of the image is relatively dark (this usually forces the camera to use slower shutter speeds, lower aperture and/or higher ISO), then these reflections (which are often not noticable) are relatively easy to spot.
The different shapes could simply be caused by the different angles at which the light beams coming from the different lights hit the lenses and are reflected back and then back again by them. You could try to photograph similar scenes.
response?
Unfortunately not.
But don't miss the Iridium Flares:
http://satobs.org/iridium.html
Cheers
Snaps
DB
The people from Fuji Holland have seen these pictures and they didn't consider this as a camera problem. They proposed to make the same shot with other digital cameras and compare these photographs. If I would I could send the camera in for a check or repair. I made the pictures again and to my surprise there were no flary spots. Not with the Fuji and not with a nikon coolpix 5400. So I must say that it looks unnecessary to worry about this so called 'problem'. Probably I made a mistake with the first pictures. Maybe there was a small waterdrop on the frontlens. I'll never know. So my apologize for spoiling your photofun with this really nice camera.
Hmm.. waterdrop even sounds like another good explaination I didn't think of (because I try to be very careful with the lens :) ). Waterdrops could refract light like it happened there.
