Setup in the tool-
Threshold for hot pixels setting: 60
Threshold for dead pixels setting: 250
First test:
ISO 50: 10 Hot
0 Dead - use Shutter Speed Priority AE Tv, Shutter
Speed 1 second, Aperture Value 2.5 (automatically set for you),
Flash ON
ISO 50: 13 Hot
0 Dead - use the same settings as above, Flash OFF
ISO 100: 9 Hot / 0 Dead - use Shutter Speed Priority AE Tv, Shutter
Flash ON and Flash OFF have the same results
ISO 200: 23 Hot / 0 Dead - use Shutter Speed Priority AE Tv,
Shutter Speed 1 second, Aperture Value 2.5 (automatically set for
you), Flash ON and Flash OFF have the same results
ISO 400: 127 Hot / 0 Dead - use Shutter Speed Priority AE Tv,
you), Flash ON
ISO 400: 316 Hot / 0 Dead - use the same settings as above, but
Flash OFF
Second test, the camera completely cold:
ISO 50: 10 Hot
Flash ON
ISO 50: 13 Hot
Flash ON
ISO 100: 14 Hot / 0 Dead - use the same settings as above, but
Flash OFF
ISO 200: 18 Hot / 0 Dead - use Shutter Speed Priority AE Tv,
you), Flash ON
ISO 200: 24 Hot / 0 Dead - use Shutter Speed Priority AE Tv,
you), Flash OFF
ISO 400: 25 Hot / 0 Dead - use Shutter Speed Priority AE Tv,
you), Flash ON
ISO 400: 28 Hot / 0 Dead - use Shutter Speed Priority AE Tv,
you), Flash OFF
fpw
Hope this help.
Here is my question using the test program...what threshold setting
should we use to test out our G2 (for both dead and hot pixel
test)??? Anyone suggestion?
I just got my new G2! I want to test it out.
I downloaded the Dead/Hot pixel tool from
http://www.starzen.com/digicam/download.htm . How could I take a
shot with the lens cap close? On the readme.doc comes with the
download, it said "Make a lens cap shot. Close the lens with your
lens cap, also make sure to close the viewfinder so no light can
get into the camera."?? Please help me out!
fpw
Just take a picture of a solid black smooth object. (I used my
checkbook cover & my television exterior) Take this in the raw
format with superfine compression. If you have one a white pixel
will definetly stand out.
