Claude Jodoin
Member
The Foveon X3 sensor in the SD-9/10 provides a 14 megapixel TIF file from it's software based on 10.5 megapixel sampling. The X3 occurs in the Z dimension (as opposed to XY only for Kodak/Bayer sensors). There is only 33% of the TIF file data that is interpolated vs. 66% or more for bayer sensors at native pixel sampling.
[REPLY]
[REPLY]
Z (is real) - 19 hours ago
The Betterlight scan backs are range from 52 lp/mm to 125 lp/mm sampling fully measured color from lenses designed for 4x5 format. (Large format lenses tend to have lower peak MTF compared to the best 35mm lenses.) There is also some indication that they may overlap the sample positions slightly, but I can't find details on their site. (They mention "fractional pixels" but I don't see a definition.) There is also the possibility of jiggling the linear sampling array very slightly at each scan position, but I doubt the Betterlight camera does that.
(Joseph Wisniewski posted about the possibility of moving the sampling apparatus in a very small circle to accomplish low pass filtering in a discussion of Leica claiming to not need optical low pass filtering. Strikes me as a workable idea and that is the first place I'd heard of it. If one can get the mechanicals to work, it could even provide variable amounts of low pass filtering for different circumstances.)> > >
Sinar had been doing just that with their backs for quite some time. Using the "chip wiggler" aspect of piezo based pixel-shifting on the sensor for greater resolution of color and luminance.
It is possible to out-resolve the lenses in this manner, thus using the MTF limitations of the glass as low pass filters. The only penalty is the process time and huge files (well, the price of admission too).
Claude
