RichA
Well-known member
Your experience and suggestions are appreciated on how I might best photograph two opportunities only using candles as the source of light for both photos.
The kit lens has been tried with only limited success using high IOS settings and slow speeds the results were too much motion and noise.
Here are the two photos I'm trying to take.
The first is in a chapel and the focus of the picture is about 90 feet away and I hope to see about 35 to 40 feet in the FOV. There will be ten to fifteen candles lighting the subject. People could be walking when the photo is taken. The photo will be taken from a loft about ten feet above the subject.
The second photo is of one or two people from 5 to 10 feet away. I would hope to have only one candle in the FOV though other candles could be used from out side the FOV for additional lighting.
In these closer pictures I have noticed a number of different affect in the candle light itself. For example the candle light has four points or in some cases the candle light has a circle of light around it. Any ways to include or remove this effect.
I appreciate any suggestion. on lens and setting that would improve over the kit lens and an example photos would be greatly appreciated.
Thank you,
RichA
Thank you,
RichA
